Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
crwdns2934591:079crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Weird display issue after a fall
I have a MacBook which had a fall but the display isn’t broken just get a weird glitch every now and then, I was wondering if reseating the display cable could help or if the display is damaged beyond any repair
when I flex the display a little it goes away and works just fine for a while even closing and opening the display.
crwdns2942205:01crwdne2942205:0:
To make sure connect your system to an external display if the externals image is good when your internal is messing up then you have a problem with the internal display.
Not good ;-{
You’ll need to find someone with very good micro-soldering skills to see if they can save your display.
What you are seeing is the LCD displays ribbon cables to the T-CON board have become disconnected. Hopefully its just the solder joint on the T-CON board then its the T-CON board which is part of the display assembly.
Otherwise its time for a new display time:
  • 13” MacBook Pro Complete Display - Space Grey, Apple P/N 661-15732
  • 13” MacBook Pro Complete Display - Silver, Apple P/N 661-15733
MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement
I see, apple quoted me an estimate of $600, If I were to mail this laptop to Rossman repair group do you think it would be less expensive, or how much would a repair like that cost approximately ?
@Manuel Alejandro Roman Leal - You'll need to talk directly with them. There still a good possibility you may still end up needing a new display if they can't fix it.
Manuel Alejandro Roman Leal crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 42
