Touchbar not working Display Change
Hello, I’ve got a question. MacBook Pro A1989
i replaced my screen with a new one but apparently it was screen for the A2159 Modell (no Touchbar but same year as mine)
I noticed that the camera, the keyboard backlight and the Touchbar are not working and there are no options for it in the settings anymore. Coinsidence? Aren’t those screens interchangeable?
Ive heard that sometimes the camera and the keyboard backlight are not working when changing screens but the Touchbar?
Ideas?
oh and there is no Touchbar process in the activity monitor it’s like there is no Touchbar on my Modell at all.
Make sure you've ID'd your system correctly! I would recommend you plug in your systems S/N here to make sure you've correctly identified your system EveryMac - Lookup
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
Yeah so I apparently got the A2159 and the screens is for that machine but those things aren’t working since the display change. The Touchbar was perfectly fine before..
crwdns2934271:0crwdnd2934271:0 David Pfeifer crwdne2934271:0
@myth14 - So we took a left turn here! You do have the correct display as you have a A2159 system and you got the A2159 display - Two Thunderbolt model (see second parts listing below).
So either you either got a bad display or something got damaged in the process.
I don’t get it, on Wikipedia it says I’ve got the A2159 and on Ifixi it says A1989. I do have 2 thunderbolts but a Touchbar too so it’s the A2159 right? Yeah I bought a A2159 one from an eBay seller so I guess it’s the right one, can I check this in some way?
The screen is working perfectly fine, but I got no camera, no keyboard backlight and absolutely no Touchbar. Those things weren’t broke before so it must be the display right? Maybe he sold me a A1706 or A1708 one?
@myth14 - You selected the wrong system off of the iFixit systems listing. I fixed it! It is now set to the A2159 system which only has two Thunderbolt ports.
Here's the correct guide: MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement
As far as the display you'll need to see if your original display works by putting it back on (assuming it is still wrks enough to test things)
As far as what you were sold I have no clues! I rarely buy things off of Amazon or eBay as there is just too much to chance! I've given you the correct parts info below with a good supplier.
crwdns2934275:04crwdne2934275:0
