A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
Can you swap ssd in between 2 MacBook Pro?
I have a Macbook pro 2016 (A1708) which is not starting anymore (logic board dead). Can I swap it’s ssd to another A1708 and recover the data from there? Will this work or will I have issues?
If this is not possible, how can I recover data from the ssd? Are there any adaptors ?
You are very lucky! The Fn series share the same SSD drive! As long and you are careful you should be able to transfer the SSD across. Follow The fist part of this guide disconnecting the battery before you remove the SSD! MacBook Pro 13" Function Keys Late 2016 Battery Replacement
Jump to Step 10 in the MacBook Pro 13" Function Keys Late 2016 Teardown to see how the SSD is removed. Make sure you slide it out without lifting it too much (you may want to loosen the logic board a bit to get more room).
Here’s a bit more on the custom Apple SSD’s The Ultimate Guide to Apple’s Proprietary SSDs Jump down to Gen. 5 section
crwdns2886500:0MacBook Pro 13" Function Keys Late 2016crwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
crwdns2886500:0MacBook Pro 13" Function Keys Late 2016 Batterycrwdne2886500:0
1 - 2 hours
Thx a lot for the detailed info!
Mez882 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 231
