{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
crwdns2934591:0276crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Loose USB-C Ports - Replacement
I have a 2017 Touchbar MBP 13”. All four of it’s USB-C Ports are very very loose. I found replacement components here on iFixit but they don’t correspond with any repair manuals. Does an A1706 / EMC 3071 require soldering to replace these components? The replacements seem to have a standard connector, not a soldered connection.
Any help is greatly appreciated.
crwdns2942205:01crwdne2942205:0
In case anyone finds this in the future, the part does clip in, and you follow the guide entirely up until the battery removal process in the teardown. There is an aspect where you have to mess with glue on the touch ID but it sticks back down fairly easily. I loosed my adhesive with a cotton swab and Isopropyl 99% and a gentle swipe. Left glue in tact and once it dried it was ready to go back down.
The part from iFixIt has a great snap to it, but the rubber gasket doesn’t fit because it isn’t shaped like the original piece to accept it. The cover that screws to the board is also not adhered well to the part, so I did a few very light drops to reattach it, same with the foam on the top of the i/o cable.
The ports are discrete and should be replaceable without soldering. It looks like you will need to temporarily remove the logic board in the process though to remove them. Look at Steps 30 to 32 in this guide.
Thanks a lot! I just didn't want to be coming to the wrong conclusion, anything short of soldering is in my wheelhouse, just wanted another set of eyes to confirm what I was thinking.
Thanks Dan, I plan to order a set of those and swap them into a MBP Retina 13" with 4 ports.
dmetcalfe crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 656
