MacBook extremely slow and strange power button
Hello everybody,
I have a very esteemed macbook late 2011. The logic board had a problem with the detection of the ram memories (3 beeps), which was not repairable so the only solution is the replace of logic board. I managed to get a board of a macbook 2011 early version. I replace the board with very carefully, apparently without any problem and I took the opportunity to change the thermal mass of the processor.
When I try to turn on the computer, I notice that the first strange symptom was that for it to turn on, I had to leave my finger fixed on the power button for about 5 seconds. If I only clicked once, as it should be, I would hear the computer trying to connect but then it would go down. When he finally turn on i notice that is extremely slow, to the point of not being usable. I started in safe mode and it worked at normal speed.
Another thing I noticed, is that I can't reset the SMC. When I do the key combination + power button, the computer wont turn on.
Will these problems all have the same origin or will they be several problems? Do you suggest a solution?
Thank you all!
You'll need to run the onboard diagnostics to get a better idea on whats happening. Press the D key after startup to enter into it. Let us know what error codes you get.
Reference: Mac startup key combinations
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
@danj Thank you for your reply.
I just did the hardware test and got the following result:
4SNS/1/40000000: IB0R-9.166
What this means? There is some solution?
Thank you very much!
crwdns2934271:0crwdnd2934271:0 André Silva crwdne2934271:0
