crwdns2933315:010crwdne2933315:0
crwdns2934263:068crwdne2934263:0
crwdns2933315:08crwdne2933315:0
crwdns2934263:01crwdne2934263:0
crwdns2934263:019crwdne2934263:0
A1278 (EMC 2419 MacBookPro8,1) 2.3 GHz, A1278 (EMC 2419 MacBookPro8,1) 2.7 GHz
Troubleshooting
Track down a number of hardware problems using the MacBook Pro 13" Unibody Troubleshooting Guide.
Upgrades
There are a number of components in the MacBook Pro 13" Unibody Early 2011 that can be cost effectively upgraded.
  • Memory: The MacBook Pro 13" Unibody Early 2011 comes with 4 GB RAM standard, and accepts a maximum of 16 GB. If your MacBook Pro is still running with only the stock RAM, upgrading will provide a dramatic performance boost. You can upgrade to any combination of two 4 GB or 8 GB modules for 8, 12, or 16 GB of total RAM.
  • Hard Drive: 320 or 500 GB hard drives came standard with the Early 2011 MacBook Pro 13" Unibody. You can easily upgrade the drive to 750 GB, 1 TB or a lightning-fast solid state drive. For a full list of available upgrade options, check out our selection of MacBook Pro 13" Unibody Early 2011 hard drives. Be advised, at the moment you need to use a piece of software to enable trim, called Trim Enabler—this involves some risk.
  • Additional Storage: With the growing popularity of flash memory and cloud storage, you may find yourself rarely using the SuperDrive in your MacBook Pro. The optical drive can easily be replaced with a second hard drive or SSD using an optical bay hard drive enclosure. When installed, your additional hard drive will mount on your desktop just like an external hard drive.
  • Battery: The battery is certainly replaceable, even though Apple doesn't consider it to be "user serviceable." See the Battery Replacement guide above for complete replacement information.
Identification and Background
The MacBook Pro 13" Unibody is clearly differentiated from other MacBook Pros by its smaller size. However, it does resemble its larger siblings, the MacBook Pro 15" Unibody and the MacBook Pro 17" Unibody.
Use the laptop identification system to help you identify your machine. MacBook Pros tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
Tech Specs
Display
  • 13.3-inch (diagonal) LED-backlit glossy widescreen display with support for millions of colors
Storage
  • 320GB or 500GB Hard drive or 128GB, 256GB, or 512GB SSD
  • 8x DVD/CD slot-loading SuperDrive
Processor
  • 2.3GHz dual-core Intel Core i5 processor with 3MB shared L3 cache or 2.7GHz dual-core Intel Core i7 processor with 4MB shared L3 cache
Memory
  • 4GB, 8GB or 16GB of 1333MHz DDR3 memory
Wireless Connectivity
  • 802.11n Wi-Fi wireless networking; IEEE 802.11a/b/g compatible
  • Bluetooth 2.1 wireless technology
Graphics and Video
  • Intel HD Graphics 3000
  • FaceTime HD camera
  • Thunderbolt port
Ports
  • MagSafe power port
  • Gigabit Ethernet port
  • FireWire 800 port (up to 800 Mbps)
  • Two USB 2.0 ports (up to 480 Mbps)
  • Thunderbolt port (up to 10 Gbps)
  • Audio in/out
  • SDXC card slot
  • Kensington lock slot
Audio
  • Stereo speakers with subwoofer
  • Omnidirectional microphone
  • Combined headphone/line in (supports digital output)
  • Support for Apple iPhone headset with microphone
Battery and Power
  • Up to 7 hrs wireless web
  • Built-in 63.5-watt-hour lithium-polymer battery
  • 60W MagSafe Power Adapter with cable management system
Additional Information
crwdns2936751:024crwdne2936751:0 33
crwdns2936753:07crwdne2936753:0 187
crwdns2936753:030crwdne2936753:0 974
crwdns2942667:0crwdne2942667:0 1,072,089
