Can I upgrade my MacBook?
I’ll start off with saying I’m a new MacBook user. I purchased this MacBook online for just $20 it needed a charger & battery, so I bought a charger & I’m currently running it with just that. So in order for me to use it, it must be plugged in. But because I know this system is so old I would like to know how I can upgrade to a newer version as iTunes wont allow me to log in for some reason. (I can log in the the App Store) it’s currently running 10.6.8.. I have found a download link to install El Capitan so it’s currently trying to install. I won’t be using it much but it’s nice to know it’s there if I ever needed it. TIA
**UPDATE**
Installing El Capitan did not work
Here's the specs for your system: 13" MacBook 2.0 GHz Core 2 Duo (White-SR)
Wow that’s a lot of information thank you, so I’ve gathered this info from the link
Details: *This system can run the last version of OS X 10.7 "Lion" if upgraded to at least 2 GB of RAM. It is not supported booting into 64-bit mode when running Mac OS X 10.6 "Snow Leopard." It does not support "OpenCL" either. Please also note that OS X Lion is not capable of running Mac OS X apps originally written for the PowerPC processor as it does not support the "Rosetta" environment.
Does this mean that Snow leopard is the latest version I can get without upgrading the RAM? @danj
Sadly, one GB of RAM just won't give Lion the breathing room it needs. So you will need to push the RAM to 2 GB. I also recommend you make sure you have 1/4 of the drive left empty as the OS will also leverage it for Virtual RAM.
Sadly, the highest version of OS you can run is OS-X Lion 10.7.5.
Due to the age of the system its very limited. Apple does not offer any security updates for the OS so its risky to use online it’s also so not able to run the newer HTML code most web sites are using today.
You do want to replace the battery if it is unable to hold a charge, iFixit still has a few MacBook Battery these older Li-ION batts are limited to 300 cycles, most don’t even get that far 250 is the best I’ve seen Determine battery cycle count for Mac notebooks.
crwdns2886500:0Replace a 4900-5200 mAh battery compatible with MacBook model A1185. Part #661-3958, 661-4254, 661-4413.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
MacBook Battery
$79.99
Marissa crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 165
