What I would do on a machine this old is try the inverter and pray. Oftentimes it is the CCFL tube, but the panel is expensive enough to total the entire MB out. It USED to be a possible SMC reset, but once these backlights hit 10 years old, I’ve noticed they are usually bad in most cases.
HOWEVER, my strong recommendation is to get a 2012 13” Pro and a new HD cable, along with electrical tape to patch it. These are 10+ years old and use hard to find memory ($$$) and are limited to SATA I (Few currently available drives left with SATA I support). Unless you have a MCP79 (9400M) A1181 (BlackBooks stopped at Intel GMA onboard unless the case was hacked to make it work), you’re stuck at SATA I; the MCP79 northbridge enabled SATA II support and leaves you some breathing room. There are no known compatible drives left other then the Samsung SSDs.
Refer to the instructions on this question to patch it: Folder With "?" Mark Into Apple Logo Into Circle With Line & Repeat
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
When it goes dark can you still see the desktop using a flashlight held at an angle to the screen?
crwdns2934271:0crwdnd2934271:0 mayer crwdne2934271:0
Hi, yes I can.
crwdns2934271:0crwdnd2934271:0 Giovanni crwdne2934271:0
