One of the issues you face when replacing the tape’s is going to far! Yes, you want something that’s strong so the glass doesn’t fall off. But you also don’t want it so strong you need a jackhammer to get the glass off in a future repair.
So… replace the tape in the same locations and size, don’t over apply and use the correct adhesion grade tape.
iFixit offers Tesa 61395 tape which is what Apple uses. If you are only doing one system this might be a cheaper option Precut Adhesive card
You’ll want to use a Heat Gun to soften to old tape and use Jimmy, iFixit Opening Picks (Set of 6) & Suction Handle.
For a reference here’s what you’ll be facing MacBook Pro Retina Display Teardown
Frankly, I‘ve given up trying to replace the LCD panels. It takes a lot of skill to get the glass out without damaging the bezel frame and the rubber gasket. Then you still have to fight through the dust on the glass surfaces and not damaging the polarizer & defuser sheets.
Here is one source for the full assembly MacBook Air 13" (Mid 2013-2017) Display Assembly
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
Good source for the tape 3M - VHB F9473PC
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
