Thunderbolt ports (USB-C) no longer working
I just upgraded the HDD with a 1TB SSD and the RAM to 32GB. Did everything according to the ifixit guide and now the 2 USB-C (TB) ports don’t work. Tried re-installing the OS on the SSD, tried the old HDD still the ports don’t work. Tried to align them more properly like other people say but to no avail. Everything else works just fine. Any suggestions?
crwdns2944067:018crwdne2944067:0
@geegor - You do realize this system does not have USB-C compliant ports. So can you tell us what you are trying to plug in.
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
@danj I am sorry, i meant the Thunderbolt ports. I am trying to plugin a thunderbolt hub (EPICO type-c hub pro II) and an Universal Audio Apollo Quad (silver) that is Thunderbolt 2 but i connect it to the imac with a TB2 to 3 adapter. As mentioned earlier, everything was working fine before the upgrade and both the hub and the audio interface work perfectly on my MacBook Pro 14,1
crwdns2934271:0crwdnd2934271:0 geegor crwdne2934271:0
@geegor - OK, let's backup here. What happens when you plug the TB2 to TB3 adapter directly into the iMac's TB3 port with your audio adapter, does that work?
no, nothing works. I don't have a TB3 device except the hub.
So the TB2 to TB3 adapter and your audio unit directly plugged into the iMac's TB3 port does not work - Is that correct?
I suspect your ports power service is damaged. You'll need to use a power meter in-line with your device Satechi USB-C Power Meter to see whats happening.
crwdns2934275:013crwdne2934275:0
