The HP 15-r137wm TouchSmart contains the fourth generation Intel Core i3 processor with a 15.6" LED-backlit high-definition touchscreen display. It contains 6GB of RAM with a 750GB hard drive. The HP 15-r137wm TouchSmart comes complete with Windows 8. The HP 15-r137wm TouchSmart model number is 15-r137wm, which can be located on the bottom of the laptop in the far right corner under the battery.
Keyboard Zif separated from MB
I have accidentally separated the keyboard Zif connector on my HP 15-n230sa laptop from the main board. Didn't realise the tab was on the opposite side of the connector and stupidly prised it off the board.
Please would you mind taking a look at the pictures and tell me whether this can be rectified? Is there anyway to reseat it back on the board?
Thanks in advance!
I will find some who can re-solder this for me. Thank you very much for answering my question, much appreciated.
You are very lucky! The solder pads didn’t get damaged so it should be possible to re-solder the connector back down.
Now the tricky part! To do this right you need a re-work system which uses hot air. Your best bet is to find someone local to you with the needed tools to remount it.
go to hit shows on utube, the fellow speaks mostly indian, but if you watch he cuts plastic to fit over the end of the ribbon and a small piece for tension on the underside and heats them and then inserts them and they hold solid.
Andrew Hawker crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 193
