First introduced in 1997, the Rancilio Silvia is one of the best espresso machines on the market in its price range. If you take good care of your machine you can keep it running for years.
No water pumping through even though plenty of water in tank
My machine has stopped pumping water through. I can hear the pump working and there is plenty of water in the tank but no water is coming through. Any ideas on how to fix? Or, do you know anyone that would be able to fix?
I have an older model with the same problem. It looks like a Miss Audrey Rancilio (but without that label).
That kind of situation may be covered in the Owners Manual or check their site for a FAQ (Frequently Asked Questions). One thing to note to is, you may hear the pump sound, but that doesn't necessarily clear the pump as functional. May (probably) need to open up the unit for visual inspection.
Clogged piping? Could be forcing water through, but not passing. Could also be a bad/damaged pump (motor turns, doesn’t turn pump rotors)
Good luck!
Kelly Woodward crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 878
