The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
MacBook fan not turning on
I have MacBook Pro, the fan doesn’t turn on by itself but can be turned on manually with Macs fan control application.
I have tried smc and pram reset, I can’t reinstall new Mac OS due to overheating and switching it self off.
I have also used the apple diagnostics and when the fan is tested it works fine.
any ideas what it could be.
thank you.
Update (11/21/2018)
here a picture of the temperatures
You'll need to get something that can better monitor your systems thermal sensors and fans. I would recommend getting this app: TG Pro. Once you get it running take a snapshot and paste it here for us to see. Adding images to an existing question
Let's first identify your exact machine so we are all on the same page. Go under the Apple to "About this Mac" and tell us your correct machine.
Here’s the needed steps to replace your fan: MacBook Pro 13" Retina Display Early 2015 Fan Replacement and here’s the needed part MacBook Pro 13" Retina (Late 2013-Early 2015) Fan
crwdns2886500:0Replace a fan compatible with MacBook Pro 13" Retina A1502 Late 2013 to Early 2015. Part #076-1450.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$59.99
Which fan is inoperable? The left fan or the right fan? Are both fans inoperable?
If you can’t control the fans with fan control software nor does a SMC or PRAM reset help, I think the fan(s) are dead.
MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement
MacBook Pro 15" Retina (Late 2013-Mid 2015) Right Fan
MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement
crwdns2937315:0IF117-026crwdne2937315:0
crwdns2886500:0Replace a right fan compatible with MacBook Pro 15" Retina (Late 2013 - Mid 2015) A1398. Part #923-0668.crwdne2886500:0
$39.99
crwdns2886500:0MacBook Pro 15" Retina Display Mid 2015 Left Fancrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
15 - 40 minutes
crwdns2886500:0MacBook Pro 15" Retina Display Mid 2015 Right Fancrwdne2886500:0
40 minutes - 1 hour
It only has one fan as it’s a 13inch, fan works fine when manually enabled with smc or any other fan application.
@justanotheruser You picked out the wrong device! You have it listed as a 15" which has 2 fans instead of the 13" which has one fan...
Thats why I had recommended using TG Pro so we would have a better view on the fans. Even with just one fan (if this is a 13" model) you really need to see the tachometer values which your current fan control app doesn't show.
If you want to shotgun this then just replace the fan.
Frankly, I would do deeper diagnostics first, as you may have a bad connector or the line to the SMC maybe damaged somehow.
momomomo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 7,263
