Use this guide to help you replace a damaged, broken, or faulty right fan.
Note that the right fan is on the right of the machine while you're using it, and on the left while you're working on it.
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.1 mm
Two 2.3 mm
Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
Peel back the sticker covering the battery connector.
Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
Peel the right rubber cover up off the fan and fold it out of the way.
Use the tip of a spudger to push the camera cable connector out of its socket on the logic board.
Use your fingers to pull the AirPort/Camera cables up off the fan.
Carefully de-route the cables from the plastic cable guide.
Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
Remove the left connector cover.
Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
Remove the right connector cover.
Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
Peel the I/O board cable up from the adhesive securing it to the fan.
Remove the cable.
Use a T5 Torx driver to remove the following three screws securing the right fan to the logic board:
One 5.0 mm screw with a 2.0 mm long shoulder
One 4.0 mm screw with a wide head
One 4.4 mm screw
Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
Lift the fan and push it gently towards the back edge of the MacBook to free the fan cable from its socket.
Remove the fan.
crwdns2935229:047crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Great tutorial. I did not notice the screw length in the beginning. Thanks. :)
Strange noise came out of my mac. I found a screw on my right fan fell off and got stuck in the right fan.
James Bond - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Complimenti davvero, una guida veramente ben fatta. Il mio mac ringrazia :)
Gianluca Bruno - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
completed my first mac repair ever, so excited.
Franklin Byaruhanga - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I was hearing a strange buzzing / grinding noise coming from my right speaker. After ensuring it wasn’t the speakers, I realized it was the fan (would only start making the noise when the fans were kicking into high gear). I opened it up and found that one of the screws on the right fan wasn’t attached to the logic board: Step 14, top right screw (orange) attaches to a silver nut (?) which should be attached to the logic board. The adhesive that attaches the nut to the logic board had detached! Gotta find what type of adhesive I need to get for this, but putting this here for anyone with a similar problem.
Rachel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you so much - I used this to access and clean (but not replace) the fan.
CCC - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
