Intermitten LED #2 on Logic Board
I have a good working power supply. It has been tested as well as the logic board.
When I plug the AC plug into the electric outlet without turning on the system the #1 LED lights which it what it should do.
The fans keep starting and stoping and the #2 LED blinks off and on. Is this normal? When I press the start button it continue to do the same. Could there be an open circuit?
Carefully disconnect the power switch connection on the logic board. Does the #2 LED stay off and the fans are not running?
You may want to run the diagnostics. With everything connected reboot the system and hold the D key did any errors pop?
duane c johnson crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 146
