I know it’s been a while since this question was asked, and I’ve been following the answers since the recall was first announced. I’ve since replaced my Big Blue with an Aiwa Exos 9, and while it’s a nice replacement, the Big Blue is so much easier to grab and take somewhere.
This evening, I decided to take a closer look and played around with the speaker a bit. Turns out, while the Lithium Ion battery pack is ~11 volts, the charger input is 18 volts… which just so happens to be the voltage of many cordless tool batteries. Sure enough, I’m currently powering my Big Blue off of my Makita LXT batteries through a cobbled together adapter - with the internal battery removed. It’s not the most ideal solution, but it means I get my speaker back to full portability without worry of fire.
I hope this idea helps other people regain their speakers!
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
Has anyone tried any of the aforementioned fixes regarding replacing the battery with similar batteries? Or rewiring it to be powered exclusively off the power cord? I’d be fine with that as an alternative and just drop the battery power all together if that’s the safest option that still allows me to keep the speaker (I really like have it for Chromecast out on the deck and nobody else seems to make the same product functionally).
crwdns2934271:0crwdnd2934271:0 Jonathan Alstad crwdne2934271:0
You can just remove the battery no rewire required I just removed the battery and use the power cable works great.
crwdns2934271:0crwdnd2934271:0 XMTS LABREAKERS crwdne2934271:0
Solution for the pack: get a new pack that uses a protected cell like Samsung 30Q. These will internally disconnect the cell if the cell overheats.
My original pack lost capacity, so I replaced it with 7000 mah (versus 4400 mah) pack. The difference is using Samsung 35 E cells. Charger uses a near constant low current as opposed to starting with higher current and ramping down. I monitored a charge and the charging voltage reached a peak near 12. 8 volts, leaving pack at 12.6 volts, which is OK. Pack wasn't even warm to touch.
I got the pack via ebay. The pins in the plug were reversed, so I had to swap them.
Potential issues: a charger that overcharges pack. An pack with a weak cell that would overcharge that cell with pack at 12.6 volts. Something that could short circuit the pack.
Laying the charger on it's side when charging would reduce risk of fire, since the pack is at the bottom. Taking off the bottom cover to expose the pack would allow the temperature of pack to be monitored.
crwdns2934271:0crwdnd2934271:0 rcgldr crwdne2934271:0
