Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
iPhone 5s restoring gives error 2015; screen is broken
I have an iPhone 5 that I got from someone, because he dropped it and the screen broke pretty heavily. Quite a bit of the glass in the top right corner is completely gone. And he couldn't boot it anymore either.
However, I might be interested in fixing it. Question is though, how much do I have to fix?
Current symptoms;
  • When I received it, you could turn the phone on, but it wouldn't actually boot. Instead, it would reboot constantly.
  • I tried connecting it to my Mac and doing a factory reset on it through iTunes. However, after wiping the system, that fails with an 'unknown error (2015)'. This happens on all my restore attempts.
  • Now, connecting it to my computer shows 1) the Apple logo, and then 2) the image asking to connect it to iTunes.
Restore sequence;
So my question is; does anyone know if just replacing the screen would work?
Or do I have to replace something else as well?
crwdns2944067:04crwdne2944067:0
Same here i got the iphone from my sibling he said that the phone turn off and it reboots and even it is charging the iphone reboots the phone has a history of repair the battery was replace and i think the cause is the battery need help
2015 is an error regarding the insufficient charge of your battery to even enter the iOS to charge. Get a new battery.
@me_ravi I have got a new battery and also charged it over night. Yet getting same error 2015. What to do?
So, are you sure that the replaced battery is charged? Just by plugging the iphone with a cable is not called as charging. The itunes logo is not a indication of charging. If you know that it is charged, then it would be a NAND Gate problem. An expert in repairing will so the job. It requires micro level work.
You can know that iPhone is charging under 2 situations.
1. When powered off you will get a battery symbol with or without plug.
2. When powered on you know that. itunes symbol on screen is not charging.
2015 is an error regarding the internal power of your battery which should be replaced.
Boot loops are indicative of the phone failing its health check on startup, so likely there is something physically wrong with the device (at least in its current state) besides the cracked screen. If it hit hard enough in the top / top right corner then it might have damaged the front camera/speaker flex cable, the rear camera, etc
If you're comfortable trying to fix it yourself I'd give it a go. The screens for that model are really cheap these days and the experience is worth something. If it's still having issues post-replacement try not reconnecting the front ribbon cable and/or disconnecting the rear camera.
Hi there LFB I got exactly the same issue, only thing is this phone was older than 12 months but in absolute MINT condition, no scratches, screen perfect and never been dropped. I went to bed with the phone on charge, like I do with every single iPhone I have ever owned and this guy kept rebooting. The flashing light actually woke me up. So I'm not sure if its hardware failure or what. Any other suggestions? Thanks Sean
Thanks to Ravi and to LFB. I'm sure the issue is my battery (constant reboot). My iPhone 6S is intact, not even a scratch on the screen protector, and I replaced my battery at the Apple store in Boca Raton, FL on less than 3 months ago.
Bruno Scheele crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 27,450
