Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
key switch replace or repair
how to replace key swicth in the ingnition
crwdns2889612:0crwdne2889612:0 10
Open the hood to access the battery. Disconnect the negative cable to isolate the electrical power.
2
Open the driver's side door for more room to remove the ignition switch. The switch is located on the steering column.
3
Unscrew the shroud around the steering column with a Phillips head screwdriver. Pull the shroud out from around the steering column once it is loosened.
4
Locate the switch by the ignition lock. The switch will be screwed into the column.
5
Pull the wires out of the back of the switch by hand. The wiring harness will have locking tabs that must be pulled out to separate it from the switch.
6
Unscrew the switch from the column with the Phillips head screwdriver. Pull the switch out of the column.
7
Place the new switch where the old one was located. Screw the switch to the column with the Phillips head screwdriver.
8
Push the wiring harness into the back of the switch. Push in the wiring harness until it locks into place.
9
Fasten the shroud back around the steering column. Tighten the screws with the Phillips head screwdriver.
10
Connect the negative cable on the battery with a line wrench. Ensure both cables on the battery are tight.
11
Start the truck to ensure the ignition switch is functioning correctly.
I have a 1989 chevy pick up..no screws below .just 1 bolt holding wheel & the locking thing..
the rod from the key to the switch is offset that is what i need to fix
Hi,mine is just got 274000 miles on it
ron hughes crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 78
crwdns2942667:0crwdne2942667:0 34,426
