Wifi/Bluetooth assembly upper screw stripped beyond recognition
The upper screw which also holds the display assembly is stripped to the point that it's basically round, similar to the bolted screws on the mainboard.
The "rubber" / "glue" methods are out of the question.
Do you have any real suggestions for me?
I haven't tried with a drill bit yet. Should I? If yes, which size?
Are you talking about the screw in step #9 of this guide?
MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Board Replacement
If so try using these: Screw Extracting Pliers
crwdns2886500:0Pliers designed to firmly grip the heads of damaged screws. Specially designed jaws firmly grip screw heads, bolts, or nuts allowing you to twist out even the most damaged fasteners. Professional Grade tool. ESD-safe option.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$19.99
Mihai-Alexandru Cernescu crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 232
