This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
crwdns2934591:078crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Weird distortion on the right side, fixable?
As seen in the picture above, there's a distortion which only appears after the monitor has been turned on for about 30min-1hr. It's practically invisible on white and black backgrounds, but very visible on grey or sky-blue backgrounds for example.
Things I tried:
1. Use a Macbook as source, no fix
2. Use my main desktop as source through DP adaptor, no fix
Is there a way to fix it? Could it be bad caps?
Thank you !
Here's a good writeup: LCD Image Persistence on the issue. I still call it screen burn-in ;-}
The good news is if you change your background image to a full blue or grey background over time the ghosting will disappear!
Hopeful news! I will play those YT screen burn-in videos overnight. I'll post an update. Thanks!
Update: @danj, you were right! Though it took a while (16hrs), the distortion is almost gone. A little longer and it should be back to normal. Thanks again :)
Terry Newman crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 418
