Red Downhill Light Dashboard
Why is the downhill light on the dash lit on?
Hi,
Have you pressed the Downhill Brake Control switch on the dash to see if the light goes out?
The following image is taken from the 2012 Kia Sportage owner manual. (You didn't state the model year so the switch may be in a different location)
(click on image to enlarge for better viewing)
If operating and releasing the switch makes no difference and you have traveled faster than 40 m.p.h. and the light is still on, then the DBC system may be faulty. Take it to a dealer and get it checked out.
had it at the dealer and they cant fix it.
Hi,
If the dealer can't fix it (or doesn't know how to) contact Kia in your country and ask what the problem could be or contact another dealer.
They should have the service manuals and equipment to diagnose what the problem is, more than anyone else.
Got the same problem I’m aggravated with this crap I’m gonna change the switch and wheel sensors from there if nothing take it to the mechanic
Well it turned out to be a faulty led brake light triggered that crap I would of never thought that it was a bulb smh 🤦
Before eventually finding out it was a led bulb I changed the brake switch I did a four wheel brake job and I bought the wheel sensors didn’t put em in but it was next my wife said have our friend he own a shop so I dropped it off and ALSO MY BRAKE LIGHTS WOULD BE STUCK ON MY WHEN HEAD LIGHTS WERE ON AND THE KITTLE RED LIGHT CAME ON SO IT WAS A FAULTY LED BRAKE LIGHT BULB
Hi @ chris mc millan
Here’s some images taken from the iX35 owner manual that explains how to use the DBC (Downhill Brake Control) and how it can be manually activated etc.
If it isn’t manually enabled by you operating the switch then you need to take it to a dealer as they should have the service manuals and equipment to diagnose what the problem is.
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 207
crwdns2942667:0crwdne2942667:0 20,611
crwdns2944067:04crwdne2944067:0
Same problem with Hyundai x135
crwdns2934271:0crwdnd2934271:0 chris mc millan crwdne2934271:0
i had this issue, solved it by changing the switch on the clutch pedal. Not the easy access one but the one tucked up high and difficult to get to. the switch is about £40 form Kia. Took 20 mins to fit
crwdns2934271:0crwdnd2934271:0 alanstead7 crwdne2934271:0
You will fine the speed control would not be working at the same time
Also Replaced the top clutch switch on my 2015 Kia Sportage and the issue was resolved.
crwdns2934271:0crwdnd2934271:0 P Mash crwdne2934271:0
