27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
Magsafe led blinking on Thunderbolt display
Hi all,
My Macbook Air no longer charges when connected to my Thunderbolt display.
The led on the magsafe connector is blinking fast (green).
Question: what could be the problem?
Tried: cleaning the connectors / reset PRAM / reset SMC / disconnect power for long period (hours).
All the best from Holland,
Pieter
Does a regular MagSafe charger work? Solid Green and when battery is low Amber.
Hi Dan, charging works when I use another Magsafe charger (Solid Green and when battery is low Amber)
We don't have a cord or power supply replacement guide. If the cord looks OK I would suspect the power supply is having problems. Here is the IFIXIT teardown which can help guide you Apple Thunderbolt Display Teardown and here's a good guide which willl get you in Apple Thunderbolt Display EMI Filter Replacement
crwdns2886500:0Apple Thunderbolt Displaycrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
crwdns2886500:0Apple Thunderbolt Display EMI Filtercrwdne2886500:0
25 - 35 minutes
Hi Dan,
Many thanks for your answers. The cord looks OK.
The screen is fully functional. Would't there be more problems if the power supply is failing?
All the best,
Pieter
The power supply offers multiple power feeds so the MagSafe feed have a problem unlike the other feeds.
Hi Pieter,
I'm having a similar problem. Did you ever replace the power supply and did that fix your problem?
Thanks,
Viktor
Pieter crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,048
