How do I replace the LCD Cable
How can I replace the LCD Cable on the Toshiba C75D. I don't know how to disengage it from the motherboard. I don't know if it is soldered or not.
It looks like it's a cable as in Step 10 here: IBM ThinkPad X41 LCD Screen Replacement
or in Step 12 here: asus laptop k75vm replacing the broken lcd cable Replacement
This one's actually a Toshiba, if it makes you feel better. Step 7, middle picture: Toshiba Satellite A215 Teardown
Basically, it's likely not soldered down but do be careful when unplugging it. The pictures above should give some idea of how to do it, but I'd also say to throw in some patience.
You got this!
crwdns2956074:0crwdne2956074:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
30 minutes - 1 hour
25 minutes - 1 hour
Thank you so much for your answer. I can't see how to unplug it....whether it is pulled straight up....slid to the side, etc. Is there a video somewhere that actually shows how to remove it?
@marie540 Here's a video of someone removing an LCD cable from a Dell laptop (skips to the important part): https://www.youtube.com/watch?v=1_99jpJe....
And here's a video of someone replacing an LCD cable in a Toshiba (skips a fair bit, but it's a long and slow-paced video): https://www.youtube.com/watch?v=FzB4S6hq...
At about 15:32, he says that the cable eventually failed, and opens it up, if you're interested in that. You can see that the wires are frayed and broken, and he recommends opening and closing the laptop as little as possible to reduce the strain on the wires in the hinge.
Hope this helps!
crwdns2942667:0crwdne2942667:0 1,934
