Do you have to glue the replacement battery in?
I noticed that the battery on the A1389 is glued to the trackpad. If the trackpad screw needs to be adjusted (or replaced) the battery must be removed again. Doesn't it make sense to NOT peel off the clear plastic cover the adhesive so the trackpad is accessible in the future?
There are 4 screws already holding the battery in place, right?
Not really on the screws, take a look at it, they just hold down the plastic frame. Yes it's a PITA to get out. But I'd ay least cut the plastic off the two end sections and stick it down. then see if the center sections flop around to much. It's also according to how active you are and if it's getting put in back packs and is really noble. If it is really moved around a lot, I'd go ahead an d stick it in. The alternative would be to cut that plastic in half and stick it down. You know, kind of a half-a$$ed job of it ;-)
MacBook Pro 15" Retina Display Mid 2012 Battery Replacement
jimjwalker crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 628
