The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
Why my galaxy s4 getting over heat and battery drain fast?
after full charge within 20 minutes 25-30 percentage battery was losing and also it getting over heat on the top while not in use.
already i have disable some of apps that im not using.
the phone is already in the latest version ( 5.0.1 )
For me it ended up being the logic board faulty, to be specific the power management IC chip on the logic board was for some reason getting too hot, probably something connected to it was short circuited making it heat up.
The most you can do is reflash firmware / factory reset the phone and try another battery. If it's still no good then the only possible way to fix this is changing the logic board.
Personally I don't find it worth changing logic board as the phone has dropped so much in worth. I think you can get a second hand s4 for around $100.
I think this is common problem of Samsung devices. Since , uninstalling of unnecessary Apps didn't help , then kindly try to turn off some information in your device that are not in use. It could be better if you will try replace a new battery. Or the best way, try to visit any Samsung center, probably they had some reasons why it happened.
Hopefully, it can help.
SATISH ASH crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 5,068
