crwdns2947023:0crwdne2947023:0
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Stuck in boot loop
Ok this is a little long winded, and I have tried advice from other posts to no avail. I took receipt of an iPhone 5s with broken screen that would only boot as far as the apple logo (initial thoughts were the screen) after fitting the new screen still the same, I tried the new screen in my iPhone 5s no problems.
I have tried a hard reset, but it will not power down by the sleep/wake power button even if held for 5 minutes the only way to get it to power off is raise the screen and disconnect the battery also not recognised by iTunes, my next thoughts were the battery new battery tried still stuck in loop.
Anybody got any idea’s…………
crwdns2889612:0crwdne2889612:0 8
I tried to boot using itunes but got error message 9006
crwdns2933315:08crwdne2933315:0
There are a number of things that can be wrong, starting with software corruption AND/or hardware failure.
What everybody here is saying: you must first try to restore from DFU.
1/ Disconnect the front camera, leave it off.
2/ Connect a known good battery. Known good, not necessarily new.
3/ Connect screen (LCD + touch connectors only).
4/ Connect home button.
5/ Connect to computer. Turn on iTunes.
- Restore from DFU:
6/ Press and hold Power Button for 2 seconds.
7/ Keep holding Power Button and now press and hold Home Button.
8/ Keep holding both buttons for 15 seconds.
9/ Release Power Button only.
10/ Keep pressing Home Button for another 12-15 seconds.
Do you see a black screen on the iPhone and on iTunes the message "iPhone in restore mode detected?" If yes, click on restore.
If not, report back for other steps.
crwdns2889612:0crwdne2889612:0 10
crwdns2944067:08crwdne2944067:0:
Rany
Thanks for your reply I have followed your solution to the letter to get into DFU mode where previous attempts failed, however this time successful selected restore and update the serial number now shows and 2.57Gb downloaded however it goes through the motions and I now end up with the message on my laptop “The iPhone “iPhone” could not be restored. An unknown error occurred(9)” which points to the usb interface losing connection. New cable and different port on the laptop same error message.
Well we are now a little closer, and also i can now turn it on and off and when turned on the iTunes logo shows with a power cable much better than the stuck apple logo.
many thanks again.
Possible fix to error 9 is rebooting your PC
Error 9 is dropped connection. Sometimes it is due to a software issue. I had a phone that failed to UPDATE and gave error 9, but passed after wiping and restoring.
Other times = most time, it is a hardware issue.
You have to start by using "KNOWN GOOD" parts = computer USB port, cable, charging dock, battery. NEW parts are not necessarily known good.
If all the above fails after you've tried repeatedly, we can conclude to a board level issue.
There are a number of causes that are known and repairable. Others are known but repairing them is not economically sound.
Finally, after trying everything "known" the phone may still fail for unknown reasons and be deemed irreparable. Too many things can interfere with the restore process and interrupt it, thus it is an uncertain repair.
Thanks, man! It worked! I've watched dozens of tutorials today and your way to do it worked! Thanks!!!!
lolololololololololololololololololololl
Have you tried restoring or updating the iPhone through iTunes? You will need to get the phone into recovery mode in order to do so.
Can’t get into recovery mode iTunes does not see any device either also tried recboot nope nothing just a white apple logo :-( trouble is once you press the power button to power up your can’t turn it off, also tried going straight into recovery mode the iPhone has none of it at all, I have never had one be this stubborn before
İt didnt work:(
Restore or upgrade your iPhone. We are not sure the situation is caused by hardware or software.
The only thing I can think of to fix this might be factory reseting my phone, but I forgot the restrictions password I had set, and it won't let me reset it without the restrictions password. Any, and all help would be appreciated.
just use iTunes to back up your iPhone then use pin finder to get back the forgotten pin or password this works only for restriction not screen time use that one lets see how that works works for you
Hey @saltyfawn310030 if you put your phone in DFU mode you can reset the phone and as long as you remember your iCloud password (assuming the device is logged into an Apple ID) you’ll be able to get back into the phone and effectively reset it and the restrictions passcode.
Here's a great article for entering DFU mode...
https://www.payetteforward.com/how-to-pu...
What a full of bolony the solutions people give.. i had the exact problem and what worked wass dfu mode exept it wont give you errors like something with cable, have to use genuine, a very small thing interrupted the restore blablabla apple thats what apple is best at they sell you an highly over priced phone thats basicslly useless with their customer service basically having NO knowledge on trouble shooting their product. Take my advice use 3utools i even used a chinese cable knockoff and it restored flowlessly after a week of no sleep looking for fixes via that primitive itunes imazing dr.fone etc. And 3utools can download you firmwares like how torrent engines do check the file for corruption before the files are combined.
The problem may be th internals or software you can determine the problem based of what happened before it boot looped
for me i got really mad and threw it and its stuck on a boot loop seeing as i threw it it may be the internals
im not an engineer but you can fix it easily at home once you determined the problems and the solutions maybe tools.
goodluck in determining the problems=)
my 5s is either stuck on the apple logo or if above methods are tried then stuck on the support.apple.com/iphone/restore page with itunes logo and charging cable shown below it. and nothing happens not even showing in itunes.
Chris crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 168
crwdns2942667:0crwdne2942667:0 56,867
