Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Touchscreen broke after screen replacement
Hi,
Lately I have a lot of problems with the touchscreens of my screens.
If I replace the screens than sometimes there is some ghost touching or the touchscreen doesnt work.
If you unlock it than, it works again.
And this happens with multiple screens.
Am i doing something wrong?
Thanks!
I cannot stress this enough.
Make sure the iPhone metal housing frame is bent back closest to original condition so that you are not squeezing your screens in causing the digitizer to go faulty.
You can test fit the corners of the housing with the screen by placing the screen flat upside down against the frame.
It has to be easy to install the screen without requiring forcing the screen in.
Make sure iPhone housing is not bent, dented in corners obstructing screen from going in and if you really need to, file / sand off the bottom plastic of the screen a bit to make it easier to fit in due to denting / bends.
Once you see the glass separating from the plastic screen housing frame due to forcing the screen in then I recommend trying another screen because that one may already have gone faulty from forcing the screen into the housing.
I can only suggest that if your screen broke and your getting ghosting you might need to check your connections or get a better screen. I would suggest the ones sold here. iPhone 5s Screen
I use to try and save money by buying the cheap ones but kept having to hope it worked. With the ifixit units, I have not had that issue. It also has a lifetime warranty that they stand behind. Good luck. Be sure to double check connector and use the repair guides to save some time.
crwdns2886500:0Replace a screen compatible with iPhone 5s. Includes all of the small parts pre-installed in the assembly, saving time and increasing the quality of your repair. 4 inch 640 x 1136 pixel LCD Display.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPhone 5s Screen
$34.99
Clean the motherboard connector and try again.
Simon crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 105
