Adding SSD Drive to PCIe model
Can anyone assist with what parts I would need to add an SSD to a Mac Mini 2014 that came with a PCIe 512 GB drive?
I'd like to make it a dual drive setup, but can't confirm what part is needed to do so. Any help would be greatly appreciated.
me to i would like to recieve and so place a PCIE drive on my mac mini late 2014. can you send me the link for buying that item?
bst regards
@yannick17 - Review my answer for the details
If you already have the PCIe SSD then you're adding a SATA drive (either a HD or a SSD) You'll need the to follow this IFIXIT guide Mac mini Late 2014 Hard Drive Cable Replacement and need this part & tool kit: Mac mini Dual Drive Kit. Be careful here! The size of the drive needs to physically fit (12 mm is about it).
If you have a SATA HD already then you'll want this: either the drive carrier with the SSD cable mounted Hard Drive Carrier w/ SSD Flex Cable - Apple P/N 076-00040 or the cable its self Cable, SSD Flex - Apple P/N 076-00018
Here's the IFIXIT guides:
crwdns2886500:0All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$26.99
crwdns2886500:0Mac mini Late 2014 PCIe SSD Cablecrwdne2886500:0
crwdns2930805:0crwdne2930805:0
Mac mini Late 2014 PCIe SSD Cable Replacement
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
15 - 20 minutes
crwdns2886500:0Mac mini Late 2014 Hard Drive Cablecrwdne2886500:0
1 hour
crwdns2886500:0Mac mini Late 2014 Drive Traycrwdne2886500:0
Mac mini Late 2014 Drive Tray Replacement
Dan, If I already have a fusion drive in there will I need any of these replacement parts, or can I just substitute the respective PCIe and 2.5 inch drives for the existing ones?
You'll need to make a full backup before doing anything.
First step is to break the Fusion Drive following this How to split up a Fusion Drive.
And yes, all of the needed hardware sans the replacement drive/s is present.
But before you jump what is your goals here?
When adding a HDD to a PCIe SSD only 2014 mini, which HDD cable do you need? (1) the mini dual drive cable, or (2) the upper SATA cable?
tomtcs crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,553
