Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
crwdns2934591:03530crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Backlight problem on 5s
I think I need to replace the backlight filters. I've read plenty about where they are on the iPhone 5 but can't find anything on the iPhone 5s. Can anyone tell me where they are on the board and where I can buy them? Is this all I will need to replace or should I also replace the coil and ic chip.
Thank you in advance!!
crwdns2942205:01crwdne2942205:0
You have micro soldering skills and tools?
I'd check around FL24, FL25, FL26 as well as the capacitors C17, C243 and C18.
further explanation package size
crwdns2889612:0crwdne2889612:0 7
crwdns2944067:011crwdne2944067:0:
Thank you! This was exactly what I was looking for. Do you know where I can buy the filters and capacitors?
Looks like they are all in stock a digikey.com
Thanks oldturkey03. Is this the part for the filter? FILTER CHIP 120 OHM 3A 0603
Found it (I think) - FERRITE CHIP 220 OHMS 2.0A 0603
susan, the three filters are 240 OHM 0.2A 0.8 OHM in a 0201 (0603 metric) package. Available at places like this http://www.digikey.com/product-detail/en...
crwdns2934275:06crwdne2934275:0
Probably not the cheapest solution, but perhaps consider replacing the entire display assembly, digitizer en all. It's a Much Much easier job.
crwdns2942205:01crwdne2942205:0:
I already tried that. I can see the apple logo, barely, using a flashlight pointed at the display, so I think the backlight filter is blown. I'm up for replacing it/them. Can solder, just don't know where they're located. Plenty of info on the iPhone5, not much on the 5s.
Thanks!
susan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 2,308
