A handheld, user-friendly electronic label maker manufactured by Brother.
My unit wont turn on
I already replaced the ac adapter with a new one and the machine still won't turn on. I don't use the unit with batteries at all as it drains the batteries very quickly.
the screen remains blank. any suggestions?
Update
so i tested it out today with batteries and the unit turned on! Which makes me think something is wrong with the metal prong that attaches to the adapter. I also tested my adapter with my dvd player and it worked. So now I know what the problem is but can this be fixed? It looks fine to me; is not loose or broken.
i have the PT-D600 that wont turn on, or do anything at all..
Brother pulled an Apple on me and reversed the polarity on their 9v adapter. I made an adapter adapter (I call it an unadapter) so the center pin is the negative and now my generic 9v ac adapter works.
Pay attention to the (+)-c-(-) symbol beside the voltage requirement.
noosheen, start by opening it up using these guides. Then use a multimeter and plug your power adapter in. Measure the voltage on the solder points of the jack on the logic board. It is possible that it has broken off, that you have colder solder joints or that the jack itself has failed.
Remember the power adapter must be center pin negative, most adapters are center pin positive, look closely where the adapter plugs in.....there is a small symbol that shows center pin negative
Ran into this today: opened cheap Amazon charger and switched wires, works fine now.
REFER TO THESE it seems
SOMEONE MAY HAVE DROPPED IT. SOMETHING SEEMS BROKEN.
Brother PT-D200 Troubleshooting
I have bought 2 adapters and both do not turn on the machine. I have also put in 6 brand new batteries and still won't turn on.
I just had this problem too. It worked great last time I used it. Plugged it in this morning and it won't turn on with the adapter. I put in batteries, still won't turn on. Any solution?
Same problem for me too.
me too. anyone get a solution?
noosheen crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 78
crwdns2942667:0crwdne2942667:0 7,232
