Changing normal trackpad to Force Touch Trackpad?
Hello, I would like to know if it was possible to change the trackpad on my 2014 MacBook to a Force Touch Trackpad.
You'll need to wait until the system is shipped and the IFIXIT crew get their hands on one. You'll need to wait to be sure.
From what the Apple presentation shows I don't think it would work. Remember, there is more than just fitting in, the logic board needs to support it.
I own a Macbook Pro Model A1398 (15" Retina Display) and was wondering about the same issue with the Force Touch trackpad. I mean I would hope the logic board would´t have change that much. Let me know what you guys have found out.
Sorry, it won't fit. the space it uses is deeper than your current trackpad.
The reverse? Use an older trackpad in the newest model? That makes no sense!
The issue is the same across all of the older MacBook Pro Retina systems. The size of the trackpad is deeper with the Force Touch trackpad.
i think it can be but we have to wait IFIXIT maybe they have good information for us
is there a way I can replace my trackpad on my mid 2014 MacBook Pro to a force touch trackpad?
The A1502 without force touch uses a ribbon cable and the A1502 with force touch uses a socket to connect the track pad so no you can not.
Hi, and if I have a 2015 A1502 with classic pad, can i change it with Touch Force ? the motherboard seems the same :s
The 2015 A1502 doesn't have a mechanical touch pad, all of them have force touch trackpads. Unless the board inside is a late 2013-2014
Hello.. will be possible to use a 2014 normal track pad or a 2012 mac? And it’s not force touch. Just the older type.
crwdns2942667:0crwdne2942667:0 7,695
