Replace Early 2011 Logic Board with Late 2011 LB?
The GPU of my MacBook Pro (17-inch, Early 2011) crashed, leaving the it unable to boot after hanging on a screen with green vertical stripes.
Apparently a lot of MacBooks from 2011 share suffer from this (https://www.change.org/p/timothy-d-cook-...)
I was wondering, since the entire logic board needs to be replaced, if it can be replaced with the logic board of the Late 2011 series.
It's only a minor upgrade of the CPU and GPU:
Early 2011 Late 2011
Processor Number: I7-2720QM I7-2760QM
Processor Speed: 2.2 GHz 2.4 GHz
Video System: Radeon HD 6750M Radeon HD 6770M
'"Apparently it should be possible, sorry for reposting.'"
Which MacBook Logic board should I purchase?
"The boards are the same within model years... including early to late '11 so if you can find the faster (2.2GHz-2.5GHz) board it would work."
http://www.everymac.com/systems/apple/ma...
Olivier - Give your self credit here you figured it out ;-} Mark the question resolved so you get the points.
Thanks. That was helpful.
Although it has been a couple of years since I last used this MacBook, I recently tried to fix the broken GPU again.
I see this article still has some traction, so I’m posting what I did here.
A new Logic Board was too expensive, but I was able to temporarily fix the GPU issue with a specialized reflow heating machine from my univerity college. This however only lasted for about 4 or 5 moths, (untill the end of the my semester).
The only workaround I found that makes the MacBook usable again, is by disabling the GPU in the EFI vars, more info via:
https://realmacmods.com/macbook-2011-rad...
OR https://forums.macrumors.com/threads/for...
Be aware that any external screens will no longer work! (Even AirPlay screen sharing doesn't seem to be an option)
I hope this can help someone.
Olivier crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 1,285
