Repair/SSD replacement instructions for 2012 27" iMac?
I'm interested in getting a 27" iMac, but I want to install my own SSD - and I'm dreading the whole process of having to saw through the sticky tape to get into it.
Has anybody seen a posted teardown of of the 27" late 2012 iMac? Is it much different than the 21"? Will it hold two drives?
Thanks.
UPDATE: IFIXIT has posted quite a few guides now review these: iMac Intel 27" EMC 2546 Repair
You can do it if you are really into it and careful enough. Get some adhesive tape before daring it. The first teardown work is here: http://www.iclarified.com/26218/first-te....
Be careful, the teardown is not as elaborative as we see here with iFixit. You need to get some ideas from New iMac 21.5-inch iFixit tear down. It's here: iMac Intel 21.5" EMC 2544 Teardown
I hope it will help. If you liked it, please rate it and mark as accepted. Thanks. ''
I really won't suggest it for the time being as the 21" already proved to be a pain in the A**.
Here's my solution which is working great for me, it's cheaper and MUCH safer for now.
iMac 27" 2012, 3.4GHz i7 Quad Core Processor, 16GB RAM, 3TB Internal HD.
I connected a SanDisk Extreme SSD 240GB to the sata connector of a Seagate GoFlex Desk 3.5" Thunderbolt Adapter (STAE122). I have over 260MB/s writing speeds and over 370MB/s in reading speeds. Fast is an understatement but not too happy as I could achieve much faster speeds. I have a funny feeling the culprit (bottleneck) is the STAE122 as it more likely has a SATA II connector instead of a SATA III. Nevertheless, it's a perfectly fine setup for me and lightning fast.
The original forum post has quite a bit of additional information about poking around inside the new 27" iMac. Bottom line: I'll wait 6 months or so for iFixit or OWC to start carrying "upgrade kits" with the proper replacement tape & entry tools.
The 27" iMac holds one 3.5" drive (unlike the 21", which uses a 2.5" drive), and one "blade" SSD like the new MacBook Pros use. Unlike the new 21" iMac, you can upgrade the RAM on the 27" w/o cutting the machine open (there's an access hatch on the back).
Replacing the disk requires cutting open the display and removing the left speaker. You'll need a proper mounting bracket (e.g., an Icy Dock) to mount a 2.5" SSD in place of the 3.5" drive. Adding/replacing the blade SSD requires pulling out the main logic board.
Creating huge access headaches just to make the edges a 1/4" thinner is just insane.
Update: I'm disgusted enough with glued-shut computers that I opted to by a Mac Pro (trashcan) instead of the iMac. At least it opens without destroying the fasteners!
isonno crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 25,220
