crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Phone won't turn on
The screen does not turn on when the power button is pressed.
Bad/dead battery
Try charging the phone for five minutes, then turn it on again. If it is still not turning on after waiting for several minutes to charge, the battery might need to be replaced. Battery Repair Guide.
No image on display
No image appears on screen when power button is pressed.
Phone needs to be charged
Display is damaged
If the screen is cracked, flickering, or not responding when touched, you will need to replace the screen. Display Repair Guide.
Power button not responding
Phone doesn't respond when power button is pressed.
Dirty connections
Check to see if there is any debris that are preventing the button from being pushed down. Inspect the seam of where the power button meets the frame. If there appears to be something blocking the way, attempt to use a pair of tweezers to free the path.
Volume rocker does not respond
Volume will not turn up and/or down
Dirty connections
Front camera not working
Camera on the display side of the phone not working properly
Camera is not connected correctly
If the front camera won't display any visuals there may be a loose connection. Try tapping the back side of the phone to connect any loose components. If that's not the case your camera may need to be replaced.
Camera displays distorted pictures
Try cleaning the camera lens with a paper towel lightly dabbed in water. Try not to use too much water to avoid water coming into contact with any inner electronics. If this does not solve the problem you will need to replace your camera.
Camera is malfunctioning
Try turning off your phone, if the problem persist then the camera is bad or there is a loose connection. Front Camera Repair Guide.
Rear camera not working
Camera on the back side of the phone not working properly
If the rear camera wont display any visuals there may be a loose connection. Try tapping the back side of the phone to connect any loose components. If that's not the case your camera may need to be replaced.
Try turning off your phone, if the problem persist then the camera is bad or there is a loose connection. Rear Camera Repair Guide.
Travis Gregg
crwdns2935283:008/27/15crwdne2935283:0
661 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team 1-6, Sullivan Fall 2015 crwdns2935289:0USF Tampa, Team 1-6, Sullivan Fall 2015crwdne2935289:0
USFT-SULLIVAN-F15S1G6
crwdns2944067:014crwdne2944067:0
I had updated to miui 8 but after updating it asked me log in mi account but whn I log in it says u have entered wrong password even if I type correct password
aravindmohan178 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
open to app handpone not respon
FIRDAUS - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
how to setting off to security sistem
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 23,681
