crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Watch won't turn on
The screen is black, and the watch doesn't appear to be on.
Master switch is off
The first task to try is to flip the master switch on the back of the watch to "ON". Without doing this, the watch will not turn on when the home button is pressed.
Battery is not charged
The battery of this smart watch can last up to 2 weeks on a single charge, but it still needs to be recharged on a regular basis. You can do this by connecting a USB cable between the watch and a computer. Allow it to charge for about 3 hours for maximum performance.
Bad master switch
The master switch may be faulty, if neither of the above solutions solve the problem. In this case, you may need to replace the master switch.
Bad circuit board
If the master switch is in good condition, and charging the battery doesn't allow the watch to turn on, then the issue may be a bad circuit board. Replacing the circuit board entirely will be the solution.
Screen display looks abnormal
The screen doesn't display fully, the graphics aren't displayed in the right colors, or something just doesn't look right.
Screen is dirty or smudged
The screen may simply be dirty, as many children's toys become. Clean the screen with an alcohol-based wipe, or similar kid-friendly cleaning agent. Once dry, the display should look good as new.
Failure to load display properly
If the display does not load correctly and entirely, the watch software may be the culprit. Flip the master power switch to the "OFF" position for 30 seconds. Then flip the switch back to "ON" and press the home button to turn on the watch. This will reboot the watch in a fresh state, and the screen display should look normal.
Bad display
If the above solutions don't work, the problem may lie in the display itself. In that case, the circuit board (to which the display is permanently attached) may have to be replaced.
Buttons don't function
Pushing the buttons doesn't make anything happen.
Buttons are sticky
If the buttons feel stuck or sticky to the touch, they may need to be cleaned. To do so, the buttons need to be removed. Once this is done, wash the buttons and watch casing with a water-based cleaner. When fully dry, reassemble the circuit board and buttons.
Trouble connecting to computer
Despite your best efforts, the smart watch doesn't appear to connect to the computer.
Watch software error
Resetting the watch will reboot the software, and possibly get rid of any issues the watch has in connecting. To reset the watch, flip the master power switch to the "OFF" position for 30 seconds, then flip it back to "ON". Push the home button to turn the watch back on, and try connecting to the computer again.
Bad cable
If rebooting the watch doesn't work, the problem may lie in the connecting cable being used. Test the cable with another device and USB port, and if the cable fails to connect, then it may need to be replaced.
Bad USB port on computer
The USB port on the computer may be the issue. If connecting the watch works on another computer, then there's a possibility that the port on your computer is faulty. Using a different port should work.
Bad USB port on smart watch
If none of the above solutions fix the problem, then the USB port on the watch may be faulty. The only way to fix this is to replace the circuit board.
Can't view downloaded pictures/videos
Pictures and videos you've placed onto the watch can't be viewed.
Images in wrong directory
When downloading images or videos onto the smart watch, be sure that they are going into the right directory. In the Kidizoom Smart Watch location on your computer, photos should be placed in the DOWNLOAD/PHOTO folder, and videos should be placed in the DOWNLOAD/VIDEO folder.
Files are in wrong format
If your files do not show up on the watch, check which format the files are in. The watch can only accept JPEG and AVI (also known as Motion JPEG) formats for pictures and videos. If they are not in these formats, they will not be displayed.
Exposed to water and won't function
This watch may be splash-proof, but it isn't water-proof. After exposure to water, the watch doesn't work right.
Watch shuts off after being submerged
After a fall into water, you should not attempt to turn the watch back on. Doing so can cause it to short circuit, and stop working for good. Flip the master switch to "OFF" and unscrew the back of the watch. Place the watch casing (including the circuit board) in a cup full of rice, or another drying agent such as silica gel. After 3 days, replace the back plate, and the watch should hopefully function as normal.
Bad display/USB port/circuit board
If any of these parts are exposed to water, that may cause them to stop functioning. Test these parts using the relevant troubleshooting guides. If the part in question still does not work after troubleshooting, the entire circuit board may need to be replaced.
Jordan RiberSmith
crwdns2935283:001/20/16crwdne2935283:0
815 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-6, Remmell Spring 2016 crwdns2935289:0USF Tampa, Team 10-6, Remmell Spring 2016crwdne2935289:0
USFT-REMMELL-S16S10G6
crwdns2944067:0114crwdne2944067:0
I think it went in water and now the screen will only be on when charging otherwise it won't work any suggestions?
jdrsx2004 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the same issue. Did you ever get an answer?
mdearden1970 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You might have have damaged the battery causing an electrical fault. Try to change the battery from a trustworthy website to purchase a new battery
Apple Siri - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I had this problem. I kept the master switch off for a few months, then turned back back on and tried charging again. It charged properly and is working now
Cynthia Arnold - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i didnt put it in water and it wont turn on i have the same issue with my dx3
adam elsammad - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 161
crwdns2959996:0crwdne2959996:0 103,598
