Vtech Kidizoom Smart Watch DX Buttons Replacement
crwdns2869540:0crwdne2869540:0: 6783
2
16
93
6,783
crwdns2955950:0crwdne2955950:0: 7
crwdns2960004:06crwdne2960004:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 20 - 25 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
If the buttons are not working properly, this guide will help you replace them. Note: This guide requires soldering.
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Master Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
      • Flip the watch over with the back facing up.
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pull the back plate from the watch casing.
    4. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the master switch from the circuit board.
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
      • Removal of the circuit board requires soldering.
      • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
      • De-solder the black speaker wire from the circuit board.
    4. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • De-solder the red speaker wire, as in the previous step.
    5. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Buttons: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the the tweezers to pull off the blue rubber cover behind the button.
      • The blue cover is adhesive, so you can stick it back onto the back of the buttons after replacement.
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use tweezers to separate the backside tab from the front side of the button.
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push the other half of the button out of the casing.
      • Repeat steps 11 and 12 for all buttons.
Mohammed Alyaarubi
crwdns2935283:001/20/16crwdne2935283:0
365 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-6, Remmell Spring 2016 crwdns2935289:0USF Tampa, Team 10-6, Remmell Spring 2016crwdne2935289:0
USFT-REMMELL-S16S10G6
Where can you buy the replacement cover?
Katrina Nullatamby - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 93
crwdns2959996:0crwdne2959996:0 6,783
