crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device Will Not Turn On
"After holding down the power button for 5 seconds the device does not turn on. The screen remains black and there is no start up sound."
Dead Batteries
Connect the VTech InnoTab 2 power adaptor and try turning the device on by holding the power button down for 5 seconds. If the device now properly turns on consider replacing the batteries. Which can be located on the back panel of the VTech InnoTab 2.
AA Battery Replacement
This device requires 4 AA batteries to function without the power adaptor plugged in.
Follow the Battery Replacement guide to replace the dead batteries.
Defective Power Adaptor
Please make sure that the official VTech® recommended power adaptor is connected to the InnoTab 2 device. Make sure the device is connected to a live power outlet. Test by trying a different working electronic device on that outlet. If the innoTab 2 still fails to power on then we recommend buying a new VTech® adaptor.
VTech® Power Adapter Replacement
The offical VTech® adaptor can be found at VTech® AC Adaptor. The VTech AC Adaptor is specially designed to help save on batteries and provides uninterrupted gaming time. Using the unofficial adaptor may result in undesired outcomes.
Headphones Not Working
"Headphones are plugged into the VTech InnoTab 2 headphone jack, but no sound can be heard from the headphones."
Defective Headphones
Unplug headphones from the VTech InnoTab 2 and try plugging them into a working audio device. If no sound can be heard from the headphones then the headphones are faulty. If sound can be heard from the headphones then the VTech InnoTab 2 headphone jack may be faulty.
Headphone Jack Replacement
Follow the Headphone Jack Replacment guide to replace the faulty headphone jack.
Bad Picture Quality
"The VTech InnoTab 2 takes pictures but the image quality is blurred or unclear."
Dirty Camera Lens
When the VTech InnoTab 2 pictures are noticeably blurry or contains black spots the camera lens may need cleaning. Consider using a small cotton swab. Moisten one tip of the swab with water and apply gently to the lens in circular motions. After satisfied with the cleanliness of the lens use the dry side of the swab to dry the lens.
Faulty Camera
Test the VTech InnoTab 2 picture quality after completing the troubleshooting for "Dirty Camera Lens". If the image quality is still blurred or unclear the issue may be with the VTech InnoTab 2 camera.
Camera Replacement
Follow the Camera Replacement guide to replace the faulty camera.
Roberto Valdes
crwdns2935283:010/18/17crwdne2935283:0
302 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G85, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S1-G85, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S1G85
crwdns2936753:030crwdne2936753:0 35
crwdns2959996:0crwdne2959996:0 1,578
