crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
No Sound or Hard to Hear Visitor
Persistent trouble hearing the visitor through the Intercom.
Volume Set Too Low
When there is minimal sound or no sound at all, the volume may be set too low. Ensure the volume is loud enough by adjusting the volume on the side of the monitor. If this is not sufficient, ask the visitor to speak closer to the microphone.
Monitor is Dirty
If there is no sound after pressing the Talk button, the monitor may be dirty. Clean the monitor using a cleaning wipe or microfiber cloth to remove debris.
Audio Wiring is Disconnected
If there is no sound, the audio wire may be disconnected. Check to see that the audio wire is attached correctly. The audio wire is blue and should be attached to the same terminal in the Doorphone as the outside camera. Refer to the wiring diagram in the manual to check for proper installation. To make sure that the audio wiring is set up correctly use this guide.
Hard to See Visitor or Image is Unclear
The image on the monitor is hard to see.
Video Obstructions
If the screen is blank but audio can still be heard, there may be something in the way of the camera. Make sure there is nothing covering the lens or obstructing the view of the outdoor camera.
Brightness Set Too Low
If the image is unclear, the brightness may be too low. Go to the right side of the monitor and adjust the brightness slider. If the image is still unclear install additional lighting in the area the camera is facing.
Video Wiring is Disconnected
If there is static on the display or it flickers in and out, the wiring to the monitor could be attached incorrectly. To resolve this issue, make sure that the wiring to the monitor is attached correctly and that the wires are properly attached using this guide.
Door is Not Unlocked When Unlock Button is Pressed
The door remains locked even when the unlock button is pushed to unlock the door.
Monitor is Dirty
If the door does not unlock after pressing the Unlock button, the monitor may be dirty. Clean the monitor using a cleaning wipe or microfiber cloth to remove debris.
Doorbell Wiring is Disconnected
If the door is not unlocked when the door Unlock button is pressed, the wiring to the door latch could be attached incorrectly. To resolve this issue, make sure that the wiring to the door latch mechanism is wired correctly and that the wires are properly attached using this guide .
No Video Appears on Screen
Persistent trouble seeing the video feed on the screen of the intercom.
Obstructions
If the image appears to be dark, there could be an object blocking the lens. Make sure there is nothing obstructing the view of the lens on the outdoor camera.
The AC Adaptor is Disconnected
If there is no power, the AC Adapter may not be plugged into the monitor. Test to make sure the AC Adaptor is plugged into the back of the monitor.
If no video appears on the monitor, the wiring to the monitor could be attached incorrectly. To resolve this issue, make sure that the wiring to the monitor is wired correctly and that the wires are properly attached using this guide .
Doorbell Button is Stuck
The doorbell button will not depress when pushed.
Debris Blocking Doorbell
If the doorbell button is stuck, there could be debris underneath the button preventing the button from depressing. unplug all wires and take off the back plate. If there is any debris visibly blocking the path of the button, carefully clear it out. For instructions on unplugging the wires and removing the back panel, follow this guide.
Joseph Kelemen
crwdns2935283:002/14/18crwdne2935283:0
227 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G4, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S2-G4, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S2G4
crwdns2944067:013crwdne2944067:0
Screen goes off when i press unlock button.
Ajit Chhokar - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
There is no sound coming out of the speaker on my door bell. The volume is turned up to the max in the app. Can anyone help please
bukko25 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Our handset has a static sound, can't figure out why…can someone help?
new_prestige1 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
‘‘If the door does not unlock after pressing the Unlock button, the monitor may be dirty. Clean the monitor using a cleaning wipe or microfiber cloth to remove debris!!’’
Are you quite sure about this?
sammutfc - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
‘‘If the door does not unlock after pressing the Unlock button, the monitor may be dirty. Clean the monitor using a cleaning wipe or microfiber cloth to remove debris!!!’’
crwdns2936753:030crwdne2936753:0 52
crwdns2959996:0crwdne2959996:0 7,665
