crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Laptop shuts off after unplugging power cord
Dead battery
Make sure that the computer is receiving power by plugging it into a powered outlet. If it will boot after this, then the battery is suspect. Several problems will cause a battery to malfunction. Sometimes older batteries may not hold a good charge due to age, or the battery might not be recognized by the system. Make sure you leave the computer plugged in for several hours to allow the battery enough time to properly charge before presuming it to be dead. If you find your battery needs replacement follow the battery replacement guide.
Optical drive/floppy drive won't read, or optical drive won't open
Optical drive
There can be a number of issues that can cause your optical drive to stop functioning or reading discs. First, be sure the disc is not the problem. Look for scratches and try another disc if necessary. If your drive won't open try to use a paper clip and stick it in the small hole located near the tray opening button this will eject the tray and you can put your disc in. If your drive won't read at all follow the optical drive replacement guide.
Floppy drive
Like with the optical drive, if your floppy drive is not reading your disc, be sure the problem lies with the drive - try multiple floppies. If there is still a problem follow the floppy drive replacement guide.
Laptop shuts down without warning
You were working on that file and didn't have time to save it...
Overheating
This model is particularly prone to overheating, which can be a problem when you're working away and it crashes on you. Because of the age of this computer, this overheating can be caused by constant, strenuous use or possibly even a buildup of dust. The buildup of dust in the laptop can block air flow throughout, causing the device to overheat. You can carefully blow compressed air into the fan under the laptop to clear dust from it. Another reason for overheating could be that the fan itself is broken, in which case you would have to replace the fan in the computer. In order to do this, follow the fan replacement guide..
CPU Voltage Overload
The amount of time from when you start up until it crashes is seemingly random
There are some problems with the computer randomly crashing due to the CPU's capacitors overloading, causing a failsafe mechanism to kick in, which shuts off your computer. This can be remedied by replacing the logic board.
Touchpad or Right and Left Click Buttons Not Working
"Your touch is not being read by the touchpad or the cursor is moving unpredictably"
"First try to reboot your computer. If this does not fix your problem, continue reading for common problems and solutions."
Unclean Touchpod
Wipe your touchpad with a lens cleaning cloth or a damp cloth to clean it.
Touchpad Sensitivity Too Low
Your touchpad may not be able to sense your touch if the sensitivity is set too low.
Foreign Material Under Right and Left Click Buttons
Remove any debris that is visible between the touchpad and click buttons. You can remove the touchpad to clean it more thoroughly.
A Keyboard Key Does Not Work
"A key is stuck or is not showing the letter I pressed."
A Symbol I Did Not Press is Showing Up
Make sure your MS Word or other word processor is set to English. Also check to make sure your keyboard layout is correct, usually QWERTY.
Try pressing Fn+F11, Fn+NUM LOCK or Fn+F8.
The Key Will Not Move
Use a flat tool to pop off the key. Clean it with some rubbing alcohol and replace. In order to do this, follow the single key replacement guide.
Nothing Happens When a Key is Pressed
It may be necessary to replace the entire keyboard. One option is to buy a separate USB keyboard or you can use the virtual keyboard which can be found under the accessories tab.
ahintz
crwdns2935283:004/21/10crwdne2935283:0
28 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 16-3, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 16-3, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S16G3
crwdns2935297:096crwdne2935297:0
My problem is. It goes off after I save BIOS, it goes off after Windows starts. Installation goes fine. Windows 98, Windows XP... But booting something.... Even from CD (like PLOP boot manager or any linux Live CD)
Kirill Raskolenko - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 41
crwdns2959996:0crwdne2959996:0 6,383
