crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Speaker Not Charging
Speaker won't turn on when pressing the power button and does not appear to charge
Faulty Wire
This may be because the cable itself has been damaged or frayed. Inspect the cable for any signs of wear. Also, try connecting the charging cable and speaker to a different outlet to ensure that it is either the speaker or the cable that is the problem.
Bad Battery
If you're experiencing reduced battery life or difficulty charging the battery in your speaker, it's possible that the battery may need to be replaced.
Speaker Reset
While it is unlikely, you may be able to solve the problem by restarting the speaker. Hold the power button for a few seconds, and then turn it back on.
Failing To Connect To Bluetooth
Speaker remains unconnected when trying to pair with another Bluetooth device
Speaker Is Unable To Pair
If you are unable to pair to the speaker and the device isn’t showing up on your connecting devices hold the speaker's power button until all lights turn off and wait 10 seconds. Turn on the speaker again and attempt to pair the speaker to your device.
Speaker Not Showing Up On Connecting Device
If you are unable to find the speaker in your device's local Bluetooth connections make sure your phone is up to date. If you are connecting as an IOS user check your phone settings for your phone's current update and guarantee it is IOS 10 or higher in order for the speaker to be able to pair.
Distorted Audio Output Over Speaker
Audio coming out garbled, distorted, quiet, or is buzzing
Interference With Bluetooth Connection
Turn up the volume of the speaker and the connected device. Also, make sure the audio cable is disconnected from the AUDIO IN jack while trying to connect to the speaker via Bluetooth. Place the two devices close to each other. Also, turn off other Bluetooth devices within their proximity to confirm that there is no outside interference.
Bad Connection Between Speaker and Motherboard
Open the device and observe the connection between the speaker and the motherboard. Examine the wires for any tears or breaks. Also, examine the actual PH connector (the plastic piece at the end of the wire that plugs into the motherboard). Make sure it is not damaged and that an adequate and secure connection is made.
Faulty / Damaged Speaker
Verify that there is visible or audible damage on the speakers. See if one or both of the speakers are damaged. See the repair guide for replacement.
Sound Not Coming From Device Via AUX / USB Cord
No audio after plugging in USB or AUX cord to device and speaker
Poor Connection Between Device and AUX / USB Cord
If AUX/USB isn’t working properly disconnect the cable and wipe down cable ports and the port on the speaker to ensure proper connection.
Bad AUX / USB Cord
If cleaning the contacts does not work, attempt replacing the cable as this might be a cable failure.
Faulty / Damaged Port Housing PCB
Inspect the AUX and/or USB ports. Observe if there is any damage to the pins inside. Also, open the device and inspect the PCB holding the ports. If you can confirm that this component is damaged, refer to the repair guide for replacement.
LED’s not working
Lights / LEDs do not turn on while speaker is powered on
Speaker Reset
Turn the speaker off and then on using the power button. You know the speaker is on when the power indicator lights up green.
Lighting Function Turned Off
If the device’s LEDs have not already turned on, press and hold the BATT (battery)/LIGHT button behind the cap on the rear side of the speaker for about 3 seconds until the lighting function turns on.
Bad connection between LED Circuits and Motherboard
Open the device and verify that the wires are making a proper connection between the motherboard and the respective left and right LED control circuits. Also, examine the wires for any tears or breaks.
Bad LED Control PCBs
There are two LED control PCBs (right and left) that control their respective sides of the speaker’s lighting. Verify if the right, left, or both sides of the speaker’s LEDs are not lighting and replace the corresponding circuit to fix the issue. See the repair guide for replacement.
Isaac Oliveira
crwdns2935283:010/26/22crwdne2935283:0
282 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-5, Botvin Fall 2022 crwdns2935289:0UMass Dartmouth, Team 3-5, Botvin Fall 2022crwdne2935289:0
UMASSD-BOTVIN-F22S3G5
crwdns2935297:059crwdne2935297:0
Hello, ty for this guide. But I don't find the way to solve me problem. My speaker don't turn on, a light appear quicly but it's all. I don't know where can from this trouble can you help me.
Etienne Toursel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I am having the same issue. I have it all broken down and it will power on with all disconnected but when reassembled only the speaker lights turn on briefly.
Bruce - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Copier
Hi, I finded the problem for my speaker. The problem is the power buton who can't switch on, I need to dissemble the speaker and press the buton on the mother card.
I think the connection don't macth because I need to press it hardly, I use the speaker dissemble
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 3,642
