crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Camera Will Not Power On
The camera will not respond or show any sign of powering up.
Charger is Faulty
Ensure the battery charger is working properly. When charging the battery, check to see if the light on the battery charger is on . If the light is not on, the adapter is faulty. Consider purchasing a replacement battery charger.
Battery is Faulty
If the battery charger works properly, and the camera will not power on after the battery is charged. Then, the battery is faulty. Replace the battery using this guide.
Lens Mount Can't Properly Connect
Lens is not connecting to the Lens Mount.
Model of Lens is Not Suitable
Check the model of the lens is suitable with the Sony Alpha NEX-C3. If not, purchase a suitable lens.
Lens is Faulty
Check the connection part of Lens. If the connection part of Lens is seriously attrited and can not connect to the Lens Mount, consider purchasing a replacement Lens.
Lens Mount is Faulty
Check the connection part of the Lens Mount. If the connection part of the Lens Mount is seriously attrited, replace the Lens Mount using this guide.
LCD Won't Turn On
LCD screen is black and shows nothing.
Images Do Not Display
The LCD screen relies on power. If the camera does not show other signs of powering up, refer to the above section:"Camera Will Not Power On". If the power is functioning, then the LCD screen is faulty. Replace the LCD screen using this guide.
Camera Not Responding to Control Wheel
Control wheel in the back is spinning but nothing is happening.
Control Wheel Does Not Have A Response
The control wheel that allows one to scroll between photos or do other tasks is made up of a motherboard and mechanical parts. If the control wheel still spins and moves like it should, then it means that the motherboard is faulty. The motherboard for the control wheel can be replaced using this guide.
Huasheng Ye
crwdns2935283:010/12/17crwdne2935283:0
60 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
UC Santa Barbara, Team S1-G1, Weedon Fall 2017 crwdns2935289:0UC Santa Barbara, Team S1-G1, Weedon Fall 2017crwdne2935289:0
UCSB-WEEDON-F17S1G1
Having a problem with blue/red line that is straight across the photo when either in portrait or horizontal mode, how to remove it?
patty - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 63
crwdns2959996:0crwdne2959996:0 1,676
