I need to apply grip tape
Your feet cannot get a grip on the skateboard
Bought new skateboard
Your feet will need to be able to grip the skateboard in any case. It is not advised to use your skateboard without any grip tape by standing on the plain topside of the skateboard deck. If you have just recently acquired a skateboard deck and it does not have any grip tape you might want to reference the Grip Tape Application guide.
I need to replace my trucks
Your current trucks are old or damaged and you have new trucks to replace them
Trucks are worn
Each time you grind using the trucks of your skateboard, your trucks become slightly damaged. This damage is caused by all of the forces that the component is under. If you perform grinds frequently your board may begin to sit unevenly on the ground due to uneven wear on the bottom of your trucks. In this situation you should reference the Truck Installation guide.
Trucks are broken
If you perform a lot of high impact maneuvers on your skateboard, cracks may develop on your skateboard trucks. These cracks will mainly appear along the thinner part of the truck closer to the wheels. They could also be attributed to your trucks being too tight which would hinder your kingpin bushing's ability to support the truck during any high impact maneuvers. In this situation you should reference the Truck Installation guide.
Trucks are squeaky
Sometimes when turning, the trucks of the skateboard produce a squeaking sound due to the close contact of metal and rubber pieces. This problem can be solved through the use of common household soap. Please refer to Squeaky Trucks for installation instructions.
I need to replace my wheels
Your current wheels are damaged or inadequate and you have new wheels to replace them
Wheels do not have enough grip
If your wheels do not have the desired grip, you may choose to purchase wheels that are softer in order to achieve more traction when riding your skateboard. A softer wheel will have a lower "a-rating" that will be in the 60-70 range, whereas a harder wheel will be in the 90-100 range. In general a softer wheel has more grip, but wears down faster, whereas a harder wheel has less grip and wears down much more slowly. Please reference the Wheel Installation guide for assistance in changing your wheels.
Wheels are too small
Many times when riding a skateboard for a long time, the wheels begin to slowly wear down. It is nice to have some some size to your wheels as this generally helps when you are riding on the sidewalk and your wheel hits a pebble or a stick. If your wheels are big enough they will simply roll over the object. However, if they have worn down to the point where every time you hit a small rock your board stops and you fall off, it may be time for some new wheels. Please reference the Wheel Installation guide for assistance in changing your wheels.
My wheels don't spin as fast as they used to
"When you spin your wheels they do not maintain an adequate speed''
Bearings are broken
Your bearings can be damaged this way when they have had poor maintenance and you perform high impact maneuvers on your skateboard. Typically when a bearing "blows out" you see the metal balls from inside the bearing disperse and your wheel generally falls off. If your bearings have been damaged this extent, you will need to replace the damaged bearings. To do this you may reference the bearing replacement section of the Wheel Installation guide.
Bearings need maintenance
If you find that you are not coasting very efficiently, or one of your wheels isn't turning at all, it may be time to service your bearings. Over time a bearing will become slower and need to be lubricated. It is important to note if you have ridden your skateboard through water, as this will severely hinder the bearing's ability to spin due to the presence of rust. It is advised that you reference the Bearing Maintenance guide to extend the life of your bearings.
When making hard turns, my board stops suddenly
Whenever you turn your wheels are making contact with your deck
Trucks are too loose
If your trucks are too loose, this may cause the wheels to touch the bottom of the deck during hard turns. When this happens your board will stop suddenly while you are turning sending you flying off of your skateboard. Wheel bite can be particularly dangerous at high speeds and should be carefully managed. In the Wheel Bite Prevention guide, you will find multiple ways to tighten your truck setup which would prevent any sort of wheel bite from happening.
Wheels are too close to the board
In some cases, if you buy a set of wheels that are particularly large, you will need to increase the distance between the deck and the wheels in order to effectively turn while riding the skateboard. To do this you would simply add risers as necessary. It is advised that you refer to the Wheel Bite Prevention guide to perform these adjustments.
Jared Stine
crwdns2935283:010/05/12crwdne2935283:0
800 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-32, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 6-32, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S6G32
What if one of my wheels is small? For me, I have this one wheel and wherever I place it on the trucks, it will hardly touch the ground. This makes it so when I lean on the opposite side of my board that the wheel is on, my board lifts up on the wheel side making it difficult for me to do tricks. This problem started when I changed trucks and used different nuts then the ones that came with the new trucks. I don't wanna buy a whole new set of wheels, for I just got mine like 2 weeks ago. They are spitfire wheels I think. Please help me.
Nolan SB - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I got brand new minilogo trucks. When I stop riding and step out of board the trucks are stuck in last position and when I try to ride it I need to step on board with two foots before getting some speed and it triggers me. Is it because my trucks and not broken in or something else?
jirkasmurf - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My skateboard is brand new same with the wheels and for some reason my board stops at everything. I don’t understand why? I could get bigger wheels but I want to use it for tricks and stuff though
Janice roberts - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 39
crwdns2959996:0crwdne2959996:0 8,105
