Skateboard Trucks Replacement
crwdns2869540:0crwdne2869540:0: 14 тыс.
5
27
134
14 212
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 8
crwdns2959982:08crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 15 - 25 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Be sure that you have installed grip tape on your board before installing your skateboard trucks. If you have not, please see the Grip Tape Application guide. Also be aware of the type of hardware you have. This will decide whether you need an Allen Wrench or a Phillips Head Screwdriver.
    1. Skateboard Trucks Replacement, Trucks: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skateboard Trucks Replacement, Trucks: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
      • If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
    2. Skateboard Trucks Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
    3. Skateboard Trucks Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hand tighten the nut hardware onto all four bolts.
    4. Skateboard Trucks Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
      • Repeat steps 1 - 6 to install the second truck.
To uninstall your trucks, simply follow these steps in reverse order. To continue assembling your skateboard deck, see the Wheel Installation guide.
Cameron Nye
crwdns2935283:010/03/12crwdne2935283:0
79 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-32, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 6-32, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S6G32
crwdns2936753:030crwdne2936753:0 134
crwdns2959996:0crwdne2959996:0 14,212
