Skateboard Wheel Replacement
crwdns2869540:0crwdne2869540:0: 8万
2
31
184
79,997
crwdns2955950:0crwdne2955950:0: 4
crwdns2960002:01crwdne2960002:0, crwdns2960008:03crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 9
crwdns2959974:09crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 12
crwdns2959982:012crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
This manual will show you how to correctly remove wheels, change bearings, and install new wheels onto your skateboard.
You may reuse old bearings, or purchase new ones.
    1. Skateboard Wheel Replacement, The skate board fix up: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With a 13mm wrench, remove the axle nut located in the center of the wheel.
      • Set the axle nut aside, and remove the wheel.
    2. Skateboard Wheel Replacement, Remove the Bearings: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Position the wheel at the end of the axle.
      • To remove the bearings, gently pry the wheel at a downward angle.
      • Perform this prying process on both sides of the wheel.
      • A bearing spacer should fall out once the bearings are removed.
    3. Skateboard Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Position the new wheel on a flat surface.
      • Press the bearing into the hole of the new wheel.
      • Press firmly until the bearing snaps into place. The bearing's outside edges should be flush with the inside bottom edge of the wheel.
    4. Skateboard Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the wheel over.
      • Insert the bearing spacer into the back the wheel.
    5. Skateboard Wheel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Repeat the method from Step 3 to insert a bearing into the backside of the wheel.
      • With the bearings in place, the wheel can be placed on the axle.
    6. Skateboard Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide one washer onto the axle.
    7. Skateboard Wheel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the wheel onto the axle.
      • The axle should go through both bearings and the bearing spacer.
    8. Skateboard Wheel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the second washer onto the axle on the outside of the wheel.
    9. Skateboard Wheel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Tighten the axle nut firmly.
      • Do not over tighten. The wheel should spin freely.
      • Repeat steps 1-9 for the remaining wheels.
Once your wheels are installed, you can ride your skateboard. If you feel your wheels hitting the bottom of your deck when you are turning, you may want to refer to the Wheel Bite Prevention guide.
crwdns2935229:09crwdne2935229:0
Jared Stine
crwdns2935283:010/05/12crwdne2935283:0
800 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-32, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 6-32, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S6G32
Very helpful - just got a skateboard for my son and used this guide to adjust two wheels.
emvxl - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
thanks- i needed to upgrade my enjoi wheels to ricta clouds. thanks
Kenzie Peck - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Great and awesome post. It is very helpful. This blog shows the importance of blog commenting. Thanks https://skatingkits.com/best-skateboard-...
Kelly Brien - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 184
crwdns2959996:0crwdne2959996:0 79,997
