crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The vacuum won't turn on
The vacuum won't power on.
The On/Off button doesn't work
If the vacuum isn't turning on, it may be because of the on/off button. Often, the user can solve the problem by simply verifying if the on/off switch is turned on. If pressing the button to the on position doesn't work, the switch may need to be replaced.
The vacuum does not have secure power
If the on/off switch is on, but the vacuum still won't turn on, make sure your vacuum is plugged into a functioning outlet. You can easily check the power connection by wiggling the cord to make sure it does not fall out. Also, if one outlet in your home doesn't work, try plugging it into a different outlet.
The cord is faulty
If the vacuum won’t turn on, it may be because the cord is malfunctioning. The cord could be cut or damaged, preventing power from reaching the vacuum. You may have to purchase a new power cord for the vacuum.
The vacuum thermostat is too hot
If the vacuum gets too hot, it will power off automatically. The vacuum will not power on due to an integrated thermostat. Allow the vacuum to cool from the overuse and try again. To reset the thermostat, follow these steps:
1. Turn the switch on the vacuum to off.
2. Unplug the vacuum.
3. Wait 30-45 minutes for the vacuum to cool down.
4. Plug in the vacuum and turn it on to start again.
The vacuum won't pick up dirt
The vacuum is on, but will not pick up dirt or other debris.
The filters need to be cleaned
If your vacuum is on, but will not pick up dirt, then the filters may need to be cleaned out. The Shark NV352 has two filters that may require cleaning. Remove the dust cup and take out the filter from underneath it. Then, to remove the HEPA filter, take off the front of the vacuum by lifting the hatch that holds it in place. Then take both filters and run them under water until the water runs clear. Let them dry before returning them to vacuum. If cleaning the filters doesn't solve the problem, then you might need to replace one or both filters. Please refer to our HEPA Filter Replacement Guide and Filter Replacement Guide.
The dust cup needs to be emptied
If the vacuum won’t pick up dirt, the most likely reason is that the dust cup is full. When the dust cup fills, the vacuum can no longer suction and hold dirt or debris. Regularly check and empty the dust cup to keep the vacuum collecting dirt.
A blockage needs to be removed
Sometimes, a vacuum won't pick up dirt because the hoses are blocked by debris. Separate the hoses from the vacuum and visually inspect them for blockages. Also check the area where the dust bin connects to the vacuum, as dirt can accumulate there too.
The suction motor is broken
If suction no longer occurs, the suction motor could be at fault. The suction motor is found inside the suction chamber and can be replaced if desired. For help replacing the motor, use our Roller Brush Motor Replacement Guide.
The roller brush won't rotate
The vacuum is powered on, but the brush is not rotating.
The brush switch is turned off
If the roller brush is not turning, then the vacuum might not be on the correct brush setting. Check the switch, which is located on the back of the dust canister. This switch can be in three different modes, so make certain it is switched to the “II - Brush Roll On” position.
Material is caught in the brush
If some type of material is caught in the roller brush’s path of rotation, it may prevent rotation. Remove the brush, clean it, and put it back. If this does not solve the problem, then your roller brush may need replacement. To put the brush back or to replace the brush, follow the steps as directed in our Roller Brush Replacement Guide.
The suction won't function when vacuum is on
The vacuum is turned on, however, there is a loss of suction.
The hose is clogged
If the vacuum's airflow is restricted, check the hose for blockage. Buildup from using the vacuum can occur and is easily removed. Remove the hose attachments and then remove the material. Regularly check the hose for such occurrences.
The vacuum attachment is not fully connected
If the vacuum has no suction, it could be because the vacuum attachments are not fully connected to one another. Any gap between parts would allow all suction to escape. Examine the connections on the main hose and the suction shaft, reconnecting them if necessary.
If you’ve checked the other causes listed above for loss of suction, and none of the solutions has worked, the issue may lie with the motor. The easiest solution is to replace the suction motor using the Motor Replacement Guide.
Amy Moran
crwdns2935283:009/22/17crwdne2935283:0
621 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G5, Forte Fall 2017 crwdns2935289:0Cal Poly, Team S18-G5, Forte Fall 2017crwdne2935289:0
CPSU-FORTE-F17S18G5
crwdns2944067:09crwdne2944067:0
This is an incredible troubleshooting page. Well done!
Thomas Smith - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you Thomas! My peers and I put hard work and time into creating an accessible, helpful, and well organized troubleshooting page. We are coming out with a device page and repair guides soon!
Vincent Leuzze - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This doesn’t help because it doesn’t offer solution for a non rotating brush bar if the switch is in the correct position but the bar still doesn’t rotate. There is nothing restricting the brush bar.
Michael Ruggiero - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the same comment: This doesn’t help because it doesn’t offer solution for a non rotating brush bar if the switch is in the correct position but the bar still doesn’t rotate. There is nothing restricting the brush bar
Doug Pettes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Need to replace the power switch...not turning on.
Michael Drago - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 5,969
