crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Camera Will Not Turn On
Despite your best efforts, the camera will not power on.
Faulty Battery
If the camera will not turn on, make sure your battery is charged. If the battery will not charge, try replacing the battery with this guide.
Faulty Screen
Your camera may actually be on, but the screen may not be working properly. Try replacing the screen.
Flash Does Not Illuminate
The flash is turned on in the settings, but the light doesn't illuminate.
Low Battery
Make sure your battery is sufficiently charged. If not, your flash may not illuminate.
Faulty Bulb
The bulb may be burned out. Try replacing it with this guide.
Faulty Flash Power Source
The power source for the flash could be defective. Try using this guide to replace it.
Camera Won't Take a Picture
When you press the shutter button, the camera doesn't take a picture.
Wrong Shooting Mode
There are several shooting modes. Make sure you do not have your camera on a timed delay mode. Another possible mode is a "one shoot mode". This will only focus on one point in the field of view, so your camera must be focused on it to capture the image.
Faulty Shutter Button
Make sure you are pressing the shutter button all the way down. Only pressing the button halfway initiates the focus. If your camera still won't take a picture, the shutter button may not be working properly. Try replacing it with this guide.
Camera Will Not Record Video
Your camera will not record video.
Insufficient Memory
You may not have enough memory available to shoot video. Try a new memory card or delete old photos or videos to make room.
Faulty Mode Switch
If your switch is set to video mode but won't record, your mode switch may be at fault.
Screen Won't Turn On
Your camera is on, but you can not see the screen display.
Battery is Low
If your screen wont turn on you might have a low battery and will need to be charged.
Faulty Screen
Your screen may be damaged. Try replacing it.
Evert Jordan
crwdns2935283:002/08/18crwdne2935283:0
287 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S6-G2, Thomas Spring 2018 crwdns2935289:0University of North Texas, Team S6-G2, Thomas Spring 2018crwdne2935289:0
UNT-THOMAS-S18S6G2
crwdns2936753:030crwdne2936753:0 52
crwdns2959996:0crwdne2959996:0 959
