crwdns2959928:0crwdne2959928:0 ↓Is your shutter button not working correctly? Here is a replacement guide for the Samsung SCV-VLUUST50 shutter button. You will need a driver kit and a spudger to complete this replacement.
Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
Remove the corner panel by applying pressure away from the shutter button.
Remove the top panel by applying gentle pressure away from the shutter button.
Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
Remove the front and back covers by pulling them straight apart.
Remove the screw below the shutter button with a Phillips #000 screw driver.
