Outer Casing Cracked or Damaged
The outer casing is physically damaged, cracked, or blemished.
Damaged Outer Casing
You can easily separate the outer casing from the internal camera components. Doing this may allow you to either replace or separately repair the casing. Click here for a casing replacement guide.
Camera Will Not Function or Turn On
The camera will not turn on, take photos, or operate properly.
Dead Battery
Replace the batteries with new ones, and try to turn on system again.
Broken Circuit Board
If the camera is completely unresponsive and the issue is not due to physical malfunctions you may potentially want to replace the circuit board layer or parts of the board. Following the lens replacement guide will allow you to access the circuit board.
LCD Screen Will Not Turn On
'The screen remains black even when the power is turned on."
Replace Broken Display
If your screen will not turn on or is a bad display, you may need to replace the entire LCD screen. Click here for a screen replacement guide.
Lens Will Not Retract Or Respond
"The lens will not retract, respond, optically zoom, or function properly."
Dust or Dirt Jammed in Lens
Make sure to clean the lens unit and make sure there is no dirt or dust jamming the lens movement. You can use a compressed air duster or toothbrush to clean this.
Malfunctioning Lens Unit
If the lens component is not working properly (won't retract or zoom) - replacing the entire lens unit may become an option. Click here for a lens replacement guide.
Can't Close or Open Battery or Rubber Doors
"The batter or rubber doors will not shut tightly."
Dust or Dirt Jammed
Make sure to clean the door hinges and sockets. You can use a compressed air duster or toothbrush to clean this.
Misaligned Hinges
You can remove the doors by disassembling the camera, and then putting them back on to ensure hinge alignment. Click here for a battery door replacement guide and here for a rubber door replacement guide.
Broken Battery or Rubber Doors
If the outer doors do not operate correctly even after cleaning, you can remove and replace them by disassembling the camera. Click here for a battery door replacement guide and here for a rubber door replacement guide.
Yungder Lee
crwdns2935283:002/16/14crwdne2935283:0
16 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
University of Illinois Urbana-Champaign, Team 1-4, Scrogum Spring 2014 crwdns2935289:0University of Illinois Urbana-Champaign, Team 1-4, Scrogum Spring 2014crwdne2935289:0
UICU-SCROGUM-S14S1G4
crwdns2959996:0crwdne2959996:0 1,654
