crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
My phone got wet, what do I do?
Although the Samsung Galaxy S5 Active is classified as a water resistant, it is only water resistant up to 1 meter for a period of 30 min. To check if the phone has water damage, remove the battery. Below the battery is a small plastic square that ordinarily is white, if it is red the phone has suffered water damage. Whenever your device gets wet, dry it thoroughly with a clean, soft cloth. If your device is exposed to salt water, wash the device with fresh water then dry thoroughly with a clean, soft cloth. Otherwise, when it dries, salt may accumulate and block the microphone, earpiece, and speaker. When drying off your device, be sure to pat the earpiece (top front of phone), microphone (bottom of phone), and speaker (rear of phone) with a clean, soft cloth to remove as much water as possible. When making a call immediately after your device is wet, the microphone may have water in it which may lower the volume that the other person will hear. After drying off the device, allow the device to air-dry before making a call. If it doesn't work you should check the battery section.
Galaxy S5 Active won't turn on
Your phone will not boot
The battery is not correctly installed
Your battery may require a little extra force when inserting it to make sure all the pins on the battery are making contact with the phone. Without proper contact the phone will not receive power.
The battery is dead
Even when the phone is not being used it still sips power waiting for phone calls or text messages. Your battery could have died, this can be remedied by using the included charging cable, or swapping out the battery with a charged one.
Samsung Galaxy S5 Active Battery Replacement
The phone is physically damaged
Dropping your phone can cause damage to the internals even without obvious external damage. You may need to replace the motherboard or screen.
Samsung Galaxy S5 Active Display Replacement
Samsung Galaxy S5 Active Motherboard Replacement
The Galaxy S5 Active camera is unresponsive
Camera application shuts down or does not operate
An error appeared saying: "Warning: Camera Failed"
This pop-up appears and the camera will not work. There seems to be no available fix yet but Samsung is aware of this problem and are willing to replace the device if this problem arises.
The camera is broken
The phone's camera may be bad and need to be replaced.
Samsung Galaxy S5 Active Rear-Facing Camera Replacement
Samsung Galaxy S5 Active Front-Facing Camera Replacement
The camera application closes unexpectedly
The services that the camera application relies on may take too long to load or may be unresponsive. Usually a phone restart will fix the problem or you can clear the camera app's cache and data.
The camera application shows a blank screen
The phone's camera stays blank or black. Try turning off the phone, removing the battery pack, then restarting the phone. You can also try closing background apps or doing a factory reset. Remember to backup the data on your phone before doing a factory reset.
The camera lens is cracked or scratched
The camera needs to be replaced.
No sound comes from the speaker
Galaxy S5 Active is on, but no sound is coming through the speakers
The phone has low volume
The phone's volume may be low or muted. Press the volume rocker on the side of the device in either direction. An overlay will appear displaying the current volume level and a gear icon. Pressing the gear icon will display volume sliders for Ringtone, Media, Notifications, and System. The volume may be low enough that it cannot be heard over background noise.
The phone is muted
If the icon displayed in the volume settings is a speaker with a line through it, the volume is muted for that item. Drag the slider as you would to increase the volume and it will no longer be muted.
Headphones are plugged in
If headphones are plugged into the Galaxy S5 Active, the audio will be sent to the headphones and not the speaker.
The speaker is broken
The speaker in the phone may not be working. Try turning off the phone, removing and reinserting the battery, and restarting the phone. The speaker might need to be replaced.
A phone charm is in the headphone port
If you have a phone charm that plugs into the phone's headphone jack, the phone may think headphones are plugged in and not send audio to the speakers. Remove the charm and the phone will play sound through the speakers.
No sound comes from attached headphones
Headphones are plugged in, but no sound is being played through them
The phone is muted
The application does not make sound
It is possible that the application that you are using is frozen or doesn't use any audio.
There is an obstruction in the headphone port
The headphone port on your phone is always exposed and could get lint trapped inside of it. This will get in the way of the connection between the headphone's plug and the socket. Blow into the headphone port or use compressed air to clear it out.
The headphones are broken
Your headphones may be broken and need to be replaced.
The headphone port is broken
The phone's headphone port may be broken and need to be replaced.
Galaxy S5 Active is not charging
Your phone is attached to the charger but will not charge
Plugged into a computer's USB 2.0 port
The Galaxy S5 Active uses a USB 3.0 charging port instead of USB 2.0. If phone is charging while attached to your computer which does not have a "USB 3.0 SuperSpeed" port, then the device may charge slower than when it is plugged into the wall.
The wall socket is broken
Make sure the wall socket that you are plugging that charger into works by charging other devices with it.
The charger is broken
Make sure the charger is functional by testing it on another phone with a USB 3.0 charging port.
The battery is dead
The battery may be unable to charge and need to be replaced. You can buy a replacement battery from a third party or from Samsung.
The charging port is broken
The USB charging port may be broken and need to be replaced.
The SD card is not usable in software
The SD card is inserted but the phone cannot access it
The SD card is not properly inserted
If your Galaxy S5 Active does not recognize that your SD memory card is plugged in, turn off your phone, remove the battery and remove the memory card. When reinserting your memory card make sure that the gold contact pins are facing downward.
Samsung Galaxy S5 Active SIM Card Replacement
The SD card is not formatted properly
If the device does not recognize your SD card after checking the physical connection, insert it into your computer and format it with a FAT 32 file system. Remember to back up any data you have on the card, you will lose it all when you format it.
The touchscreen is not responding
The display works but will not respond to touch
The screen is dirty
Take a microfiber cloth and wipe the screen clear of any water or grease. This can interfere with the touchscreen recognition.
The screen is broken
Screen needs to be replaced.
You are wearing gloves
Most gloves will interfere with touchscreen sensors. Take off any material covering your hands.
The phone cannot make Calls
The phone is working normally, except it cannot make calls
The phone is in airplane mode
Make sure that your device is not in airplane mode.
The phone has no service
Check if your device has cellular reception where you are.
The phone has a bad cellular antennae
If you are unable to make a call even after restarting your device and relocating to a location that is known to have cell service you may need to replace the motherbaord or cellular antennae.
Nils David Corrales Tovar
crwdns2935283:009/22/14crwdne2935283:0
3,228 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-5, Hickman Fall 2014 crwdns2935289:0USF Tampa, Team 1-5, Hickman Fall 2014crwdne2935289:0
USFT-HICKMAN-F14S1G5
crwdns2935297:084crwdne2935297:0
crwdns2944067:015crwdne2944067:0
Everytime I hit the home button, it takes me to "Search, or say "OK Google" bar. Why???? It's so frustrating.
Patricia - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
dont push the home button more than once...
Jenna Rose - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Did you ever find a solution? My phone does the same thing.
Sam Gebreslassie - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
thats because S5 has different Home button function.
<Menu key>
-tap once: App drawer/ App list.
-tap and hold: Menu function.
<Home key>
-tap once: Home
-tap and hold: Google search
patisoy108 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My phone has never been in water. Unable to make calls but can surf Internet. Sent to samsung as I thought it was a virus. They say the sdm card connector is tarnished and won't fix saying it has water damage. The phone is only 3 mos old. Any suggestions on how to fix. Samsung support bad.
bruns - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 66,632
