The display removal or replacement is a procedure of moderate difficulty. It involves the use of a few tools such as a guitar pick, and a heat gun. You should be aware of the hazards and safety procedures of these tools before starting the process.
Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Use your fingers to remove the SIM card
Use a heat gun at an approximate distance of 2-3 inches from the phone to apply heat to the phone and loosen up the adhesive in the display.
Starting from the upper left corner, insert a guitar pick in between the display and the phone case.
Use the pick to pry the display by sliding the pick in the direction shown.
Use the pick to pry the sides and lower part of the display by sliding the pick through the phone.
Using the guitar pick, lift the screen slightly.
Slightly lift, but do not remove, the upper end of display assembly.
Use the sharp tip of a guitar pick to lift the front panel assembly cable connector straight up off its socket on the motherboard.
Safely remove the front panel assembly from phone.
crwdns2935229:055crwdne2935229:0
crwdns2947412:011crwdne2947412:0
I think steps 7 through 9 are still helpful. They have some important additional info that I would not want to miss ...
bposh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If your screen is already broken you don't have to use so much heat. Once a corner is up and broken simply peel the screen off. Be aware that it will make a mess, so try to do this in a plastic bag or something
mangerszve - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How do I just repare a cracked screen. Not the LCD
Lorenzo Fernandez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It's a really difficult and risky repair unless you have specialized tools. You can use a hot plate to separate the lcd from the glass and work it apart with a playing card, then use a special uv adhesive to attach the new one . Most skilled technicians and repair shops won't attempt this repair because of how fragile the lcd is. They make machines that automatically separate the lcd from the glass but it's still a risky repair. I wouldn't recommend trying it unless you want to do it as a learning experience. You'll most likely have to replace the entire screen.
Zach - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My question is can I use the LCD screen from Samsung Galaxy s5 to Samsung Galaxy s5 active? , I mean took out the glass just using lcd only
littlesecretforyou11 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
